Bosch III 42 Lb/hr Green Giant Injector Parameters
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Guys,
I am presently tuning a 7730 and these are the injectors in use.
Bosch III : 0280-155-968.
According to Bosch, these injectors flow 310 g/min with N-Heptane @ 43.5 PSI.
With Gasoline, the flow rate should be 3% to 4% greater when compared to N-Heptane.
These injectors should flow somewhere around 319.3 g/min to 322.4 g/min.
1 lb = 453.59237 g.
1 hr = 60 minutes.
When converted to Lbs/Hr ( g/min*2.204623E-3*60), the expected flow range is 41.00 lb/hr to 42.65 lb/hr. The average is 41.83 lb/hr.
I found an Injector Calibration Summary on the Web for these injectors. It was found on a Bosch Dealer Website. I wonder if it was originally developed by Ford racing?
Anyway, the "High Pulse Width" (AHISL) slope is listed as 0.011947 lb/s. In lb/hr this is 43 lb/hr. This is ~ 3 % larger when compared to the calculations that are based on Bosch data.
The Calibration Summary has a "Target Injection Pressure" of 39.15 psid.
It appears like all of the Injector dynamics variables are based off of 39.15 psid?
Any ideas on why the flow rate is higher on the Calibration Summary?
The reference files are attached.
I am working on an Excel sheet that will "map" Ford Fuel Injector parameters to the GM equivalent.
Best Regards,
Bruce
1 lb = 453.59237 g.
1 hr = 60 minutes.
Best Regards,
Bruce
Re: Bosch III 42 Lb/hr Green Giant Injector Parameters
The use of 39 PSId is likely due to the Ford's lower rail pressure of 39 PSIG.
The only application I know of that uses these in a stock application is by Ford, in the Lightning. Possibly the same supercharged engine when installed in the Mustang, but I want to say the Mustang used a larger injector.
I'm actually trying to find a set of these, becaus ethey would be about perfect for my application. I have a set of low-Z 42/lbs injectors, but I don't think they are working well with my ECM.
Car: 87 IROC
Engine: 420 EFI
I can not remember where I purchased these injectors. When I get home, I will send out the information.
Car: check
Engine: check
Transmission: check
If it helps here they are at 44 psi fuel pressure:
Injector Data Sheet: 280 155 968, 42 #/hr Skinny Greens
Fuel Pressure: 44
Flow rate: 45.0 #/hr
Minimum PW @ 44 psi: 1.173
Offset Compensation versus Battery Voltage:
6.4 Volts: 4285 usec
8.0 Volts: 2168 usec
9.6 Volts: 1465 usec
11.2 Volts: 1096 usec
12.8 Volts: 839 usec
14.4 Volts: 655 usec
15.0 Volts: 596 usec
Short PW Compensation versus Pulse Width:
0.015 msec: -118 usec
0.244 msec: -101 usec
0.488 msec: -82 usec
0.732 msec: -64 usec
0.976 msec: -46 usec
1.220 msec: -27 usec
1.460 msec: -10 usec
1.708 msec: 0 usec
1.950 msec: 0 usec
2.197 msec: 0 usec
2.440 msec: 0 usec
2.685 msec: 0 usec
2.929 msec: 0 usec
3.170 msec: 0 usec
3.410 msec: 0 usec
3.660 msec: 0 usec
3.900 msec: 0 usec
Ford Motorsport sells them (or used too) which is why the data is available.
RBob.
Fuel Pressure: 44
1.708 msec: 0 usec
1.950 msec: 0 usec
2.197 msec: 0 usec
2.440 msec: 0 usec
2.685 msec: 0 usec
2.929 msec: 0 usec
3.170 msec: 0 usec
3.410 msec: 0 usec
3.660 msec: 0 usec
3.900 msec: 0 usec
RBob.
Hey Rob, we actually stock these injectors. It turns out that some of the Volvo turbo applications use these injectors as stock as well. Where did you get the info on the offsets? Just curious, as they flow 42lbs/440cc at 43.5psi on our benches so I'm not sure where the 45lb at 44psi came from.
Yes,Ford pressure is 39psi depending on the application.
There is a difference in flow when using heptane as a calibration fluid when flowing injectors on a bench. Heptane has a specific gravity that is lower than fuel. The calibration fluid that we use is specifically from the manufacturer that makes our machines. The specific gravity is about the same as fuel. So they actually flow a little more.
For anyone who needs these injectors we have them in stock, so if we can help you in any way, please give us a shout.
Car: 87 IROC
Engine: 420 EFI
Hi Guys,
Thanks RBob.
I calculated the expected injector flow with the Ford modeling parameters.
I assume that these are valid for Gasoline as opposed to N-Heptane.
The High Pulse Width (linear flow region) flow calculated @ ~ 45 lb/hr @ 43.5 PSID. This agrees with your data.
My Bosch data based calculations resulted in a flow rate of 41 lb/hr to 42.65 lb/hr @ 43.5 PSI. The exact answer is a function of the Gasoline Density (specific gravity).
Not sure which one is correct?
Best Regards,
Bruce
Thanks RBob.
Best Regards,
Bruce
1 Post
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
when I get my bench back together I need to do back to back tests of several test fluids and develop a correction factor for each, including different types of gasoline.
Car: 87 IROC
Engine: 420 EFI
The test bench data sounds very interesting. The best way to go to answer the question.
It seems like both data sources (Bosch, Ford Motor Sports) would be correct? Unfortunately, there is a significant difference.
Did Bosch make more than one 42 lb/hr injector? I am running the Bosch III skinny injectors. I wonder if the Calibration Parameters within the sheet that I attached to this thread are correct for these injectors?
This thread started because I am presently tuning the VE Tables for my 420 SBC. This engine pulls around 10" Hg at 900 RPM. My problem is the ECM is pulling significant fuel for idle through part throttle. Originally thought the VE Table was really off.
Although the VE Table needs some work, I also have problems with the Injector Constant and Fuel Pressure adjustment.
Injector Constant = 40 lb/hr.
Fuel Pressure = 47 PSIG.
Both of these settings came from the engine dyno run.
If we believe the Bosch Data, the actual flow rate (this setup) should be around, 43.7 lb/hr.
Compared to the Injector Constant, this would cause a 9.25% rich condition. Roughly a BLM of 116.
I started running my car on the street with the dyno tune. My thought was this would be a good start. Not sure now?
Best Regards,
Bruce
Best Regards,
Bruce
Car: check
Engine: check
Transmission: check
Southbay, Injector Dynamics has been creating the data for Ford Motorsports. The spec sheets are on the Ford web site. The difficult part has been matching a data sheet to the Bosch part number.
Apparently, Muscle Motors has been taking the data sheets and putting the Bosch number at the top. These two sheets match exactly:
M-9593-F302 Calibration Summary (Ford's data sheet)
0280155968 Calibration Summary (Muscle Motors data sheet)
BWilcox posted the Muscle Motors sheet above.
For the injector flow look at the AHISL value, that is the high slope flow in lbs/sec. Multiply by 3600 for lbs/hr. There is additional information in the sheets that compensate for the fuel pressure.
The way I am doing the calculations isn't exact for the way GM uses the injector compensation. But it is close enough. Note that the data sheet data matches how the Ford ECMs use the compensation values.
Back to AHISL for these injectors (skinny green), it is 0.011947 lbs/sec. Which is 43 lb/hr at 39.15 psi.
RBob.
RBob.
Car: 87 IROC
Engine: 420 EFI
Thanks Guys,
It seems like a logical "anchor point" for the VE Tables is the Injector Constant.
However, obtaining an accurate number for this parameter is a challenge for the average hobbyist like me.
Best Regards,
Bruce
Best Regards,
Bruce
Car: 87 IROC
Engine: 420 EFI
Hi RBob,
Given the $8D Mask, is there a Minimum Pulse Width parameter?
Been searching and could not find one.
Best Regards,
Bruce
Best Regards,
Bruce
Car: check
Engine: check
Transmission: check
There is but GM set it to 0 in at least one calibration (AXCN):
L83E9: FDB 0000 ; 0 usec, MIN BPW
L83EB: FDB 0073 ; 1098 usec, SINGLE FIRE BPW DISABLE THRESH
L83ED: FDB 0056 ; 854 usec, SINGLE FIRE BPW ENABLE THRESH
L83EF: FDB 0056 ; 854 usec, MIN ASYNC PULSE
RBob.
RBob.
Car: 87 IROC
Engine: 420 EFI
Hi RBob,
I checked the AUJP BIN.
The parameters are set to the same values.
Min PW = 0 mS.
Best Regards,
Bruce
Min PW = 0 mS.
Best Regards,
Bruce
Car: 89 RS Camaro
Engine: 355, G1 trickflows, XR282HR
Transmission: TKO 600
Axle/Gears: Strange 12 bolt/4:10
I actually have a set of FM's 42 lb/hr brand new in a box for sale.
https://www.thirdgen.org/forums/engi...-cleanout.html
Car: 87 IROC
Engine: 420 EFI
Hi Guys,
Does Double Fire mean all injectors fire once each 360 degrees of crank rotation?
Does Single Fire mean all injectors fire once each 720 degrees of rotation?
I have noticed that during the VE tuning of my set-up, the Injector Pulse widths at idle are getting within range of the minimum PW value.
These Injectors are scalled properly for maximum power.
For my case, would it be a good idea to update the Single-Fire Mode enable/disable parameters?
If so, should the Single-Fire threshold be larger than the expected Idle PW value?
Best Regards,
Bruce
Best Regards,
Bruce
Car: 87 IROC
Engine: 420 EFI
Hi Guys,
It is ok to program negative Short PW Compensation vs. Pulse Width numbers in an $8D Mask?
Best Regards,
Bruce
Best Regards,
Bruce
hate to bump a 5 year old thread, but here goes.
are these the old green top. Ford injector data? mine have a different number on them, I believe they are from a lightening but I got them used, a long time ago, so who knows.
I think there's 2 different green top injectors. after posting i found they do call the newer ones green top/monsters. but they are still 42lb made by Bosch. just replace the old style I have? I found this on a random site for the offsets of the older ones.
Ford SVO Green Top 42 lb Fuel Injectors
Ford Part # M-9593-F302
Bosch Part # XL3V-A9A and 280150558
42 lb/hr. @ 39.15 psi
Minimum Pulse Width: 1.13 ms
Injector Offset:
V - ms
6 - 4.986
8 - 2.098
10 - 1.321
11 - 1.095
12 - .919
13 - .786
14 - .670
15 - .575
just posting those to try and clear up the confusion I started lol. incase this thread pops up in someone's search.
Injector Offset:
V - ms
6 - 4.986
8 - 2.098
10 - 1.321
11 - 1.095
12 - .919
13 - .786
14 - .670
15 - .575
Are you talking about the green giants? The look exactly like the Bosch lll injectors only they're green. They flow 42lb/440cc. Do your injectors work?
so there's my old ones, something called the green monster and another green giant? all 3 different part numbers? man injectors have flooded the market over the last few years.
Car: check
Engine: check
Transmission: check
Here is the green tops injector data at 45 psi:
Injector Data Sheet: M-9593-F302, 280-150-558, 42 #/hr Green Tops
Fuel Pressure: 45
Flow rate: 45.6 #/hr
Minimum PW @ 45 psi: 1179 usec
6.4 Volts: 4307 usec
8.0 Volts: 2180 usec
9.6 Volts: 1473 usec
11.2 Volts: 1101 usec
12.8 Volts: 844 usec
14.4 Volts: 659 usec
15.0 Volts: 600 usec
0.488 msec: -83 usec
1.220 msec: -28 usec
1.708 msec: 0 usec
1.950 msec: 0 usec
2.197 msec: 0 usec
2.440 msec: 0 usec
2.685 msec: 0 usec
2.929 msec: 0 usec
3.170 msec: 0 usec
3.410 msec: 0 usec
3.660 msec: 0 usec
3.900 msec: 0 usec
RBob.
Fuel Pressure: 45
1.708 msec: 0 usec
1.950 msec: 0 usec
2.197 msec: 0 usec
2.440 msec: 0 usec
2.685 msec: 0 usec
2.929 msec: 0 usec
3.170 msec: 0 usec
3.410 msec: 0 usec
3.660 msec: 0 usec
3.900 msec: 0 usec
RBob.
Car: 89 Corvette
Engine: 383, hsr intake, xr288hr-10,
Transmission: 700r4 , transgo shift kit, 3k stall
thanks , i the same ones. Looking all through tunerpro rt and have not found anything in parameter tree that has these values.
Is there a keyword search that will window pop up for injector settings?
Car: 89 Corvette
thanks here are the files: $6E mask id
TunerPro RT bin modifications file.6E.xdf
Car: 89 Corvette
Found the window for the settings
current settings:
VDC usec
0.0: 610.36
1.6: 610.36
3.2: 610.36
4.8: 610.36
6.4: 5706.87.....4307
8.0: 2319.37......2180
9.6: 1495.38.......1473
11.2: 1129.17......1101
12.8: 671.40........844
14.4: 488.29......659
16.0: 457.77.......15.0=600
17.6: 305.18
19.2: 152.59
20.8: 30.52
22.4: 0.00
24.0: 0.00
25.6: 274.66
Just insert these values and smooth the other 11 out?
1.708 msec: 0 usec
1.950 msec: 0 usec
2.197 msec: 0 usec
2.440 msec: 0 usec
2.685 msec: 0 usec
2.929 msec: 0 usec
3.170 msec: 0 usec
3.410 msec: 0 usec
3.660 msec: 0 usec
3.900 msec: 0 usec
current settings:
VDC usec
0.0: 610.36
1.6: 610.36
3.2: 610.36
4.8: 610.36
17.6: 305.18
19.2: 152.59
20.8: 30.52
22.4: 0.00
24.0: 0.00
25.6: 274.66
1.708 msec: 0 usec
1.950 msec: 0 usec
2.197 msec: 0 usec
2.440 msec: 0 usec
2.685 msec: 0 usec
2.929 msec: 0 usec
3.170 msec: 0 usec
3.410 msec: 0 usec
3.660 msec: 0 usec
3.900 msec: 0 usec
Car: 89 Corvette
here is the adjustments without altering the other 11... lol
