Blue Connected to Red Error constantly flashing when trying to datalog
Car: 1988 IROC Convertible
My setup is a 1988 IROC convertible LB9 auto with an SD conversion to a 730. I'm using TunerProRT v5 and I've been trying to datalog using a Moates APU1 which I have been able to successfully use to burn an adequate chip starting with AXXB with the following changes:
Edit Log for AXXB_91_F-car_5_0TPI_auto.bin created by TunerPro.
01/03/2015 22:25:35 Flag: Option Word 1 - Bit 4 - VATS changed from Set to Not Set..
01/03/2015 22:32:18 Scalar: SETUP, Injector Flow Rate changed from 19.76 Lbs/Hr (0x0202) to 21.99 Lbs/Hr (0x01CE).
01/03/2015 22:39:04 Scalar: EGR , Enable Min. MAT Temp. changed from 22.67 Deg. C (0x2E) to 125.66 Deg. C (0xFF).
01/03/2015 22:39:22 Scalar: AIR , Enable Min Coolant Temp changed from 35.97 Deg. C (0x49) to 125.66 Deg. C (0xFF).
01/03/2015 22:39:52 Scalar: CCP Enable Min. Temp. changed from 25.3 Deg. C (0x57) to 151.3 Deg. C (0xFF).
01/03/2015 22:42:02 Flag: Option Word 4 - Bit 0 - ERR 32 EGR DISABLED IF PASS 1 TIME changed from Set to Not Set..
01/03/2015 22:42:13 Flag: ERROR WD 2 - Bit 3 - ERR 32 EGR Valve changed from Set to Not Set..
I've also been able to successfully do some emulation. I'm using 8D_SAUJP_V4a adx and xdf.
The problem is that when I connect for dataloging, the DA: Connected blue sign constantly changed to DA: Error red sign with the error count increasing. Data is momentarily when connected. I've found some threads stating some communication issues with Corvettes that seem to address this issue but none have been solved.
Any suggestions?
Any suggestions?
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Blue Connected to Red Error constantly flashing when trying to datalog
Increase the delay between macro execution.
The repeat time of the command is too fast and is possibly overwriting data and corrupting it.
Edit the ADX definition
Mode 1 request
Increase the pause command to 25 or 50 to start with.
Make as fast as you can before errors then back it down until you are sure no errors.
HTH
Mode 1 request
HTH
Thanks a lot for your reply. I set to 25 and worked for a minute or so, then started giving errors again. I played around with it and wound up with 30 but haven't had time to thoroughly test. I'll let you know. Thanks again.
I tried all sorts of settings from 5 to 50 all with the same results. Sometimes it connects for a bit, then starts flashing again, sometimes it won't connect at all. Most stable connection was with a setting of 35 but even that only worked sometimes.
I was never able to get this to work and I read somewhere that goimg back to TunerProRT V4 may solve the issue. Problem is I can't find an SAUJP package with an ADS instead of an ADX file.
You should be able to dig up the ADS under the Moates files at the Gearhead EFI website. I have a question about your BIN edit, it appears you are disabling MAT. Why, and what effect would this have? I have done a little editing, and have never understood exactly what MAT does. I would like to do away with the sensor if not necessary.
The MAT is used to disable EGR which I have deleted. I liked through the files and I can't find it. I'll keep looking.
I used the 7730 ADS in this file:
Index of /gearhead-efi/moates/1 Moates Fileman/4) Datastream Definitions
So if you don't use EGR you don't need MAT?
If I use the 7730 ADS, it is no longer compatible with SAUJP and therefore my bin will not work either. I could go ahead and modify my AXXF bin again but I was hoping to stick with SAUJP because the layout is great.
I'm no expert but from what I read on the forums the MAT sensor is what is used to activate EGR when it senses a certain temperature. Raising this temperature to a point that will never be reached (125.66 deg C or 258 def F) in effect deactivates the EGR since the ECM will never activate it.
Mode 1 request
HTH
Mode 1 request
HTH
Thanks!
Linson
08-21-2015 02:12 PM
