S_AUJP TBI/2 cylinder
Has anyone used S_AUJP on a 2 cylinder engine with any success? I read a thread where someone is running the peak and hold drivers on a 7749 with it for a TBI setup but that's about it. It seems like it should work.
I've got a 7727, wideband, and two suitable injectors and I would like to run the injectors in each port, not in the TB.
I will machine my own throttle body with a map, IAT, and IAC on it. My plan is to build a crank wheel (no access to the cam for anything) with a VR sensor to trigger an HEI ignition module. On the bench the GM cam sensor I found does trigger an HEI 7-pin module, but I need to set up a better test.
