Epromer 5 voltage
Re: Epromer 5 voltage
(Power DC Adapter should not supply more than
12Vdc at the jack output - positive center - you
must use a 9V@300mA or 9V@500mA adapter.
The adapter supplied with packages 2 and 3 below
is a special version regulated 7V @ 700mA)
http://ustr.sancaleve.com/epromer5/index.shtml
Measure the power jack size , most smaller devices use a 2.1mm
