S_AUJP v5 Log File Analyzer
Speed Density Log File Analyzer
A Log File Analyzer is now available to analyze a S_AUJP v5 Log File and report the Log File data in a variety of useful formats. If an ADX file distributed with S_AUJP v5 is used to create a Log File, no changes to the Analyzer are required.
The Analyzer can also be used to analyze any Log File produced by BINs prior to v5, but changes are required to the Log File Column Descriptions in the Analyzer to match those in the Log File.
The Analyzer provides:
- Input & BLM Table Fueling Tab: For each BLM Cell 0-15, provides Average, Minimum and Maximum values for BLM and INT by RPM Range and Manifold Pressure (kPa) Range
- VE Table Fueling Tab: For each range of RPMs in the VE Tables provides, Average, Minimum and Maximum values for:
- ◦BLM and INT
- ◦Manifold Pressure (kPa)
- ◦TPS%
- BLM and INT values are also provided for each cell in the 3D VE Tables used during the logging session.
- VE CORRECTION Tab: VE Table INT and BLM values from the ‘VE Table Fueling’ Tab above are provided along with VE Table Change Factors for each cell of the VE Tables. These values can be copied to a VE Correction Spreadsheet to quickly compute changes needed to the VE Tables to correct INTs or BLMs to 128.
- TRUE Idle Tab: Provides data while idling in P/N (IAC Position, BPW, kPa, and SA-TDC) in 25 RPM increments up to 1200 RPM for easy idle tuning. The kPa values can be used to change BLM cell boundaries to ensure they are not crossed while idling.
- Knock Count & Spark Retard Tab: Knock Counts and Knock Spark Retard with corresponding RPM, SA-TDC, MAP kPa and TPS% values
- SA-TDC & MAP (kPa) Tab: SA-TDC .vs. MAP (kPa) and MAP (kPa) .vs. SA-TDC Analysis. Also shows SA-TDC in Spark Table format.
- Injector Information Tab: Provides by RPM range:◦
- Base Pulse Width
- Fuel Pump and Keyed Ignition Voltage
- Time Between Distributor Reference Pulses
- Injector Duty Cycles
- IAC Position, MAP & TPS% Tab: For all RPM ranges, provides IAC Position, MAP (kPa) and TPS%
- MAT & Coolant Temp Tab: Analysis of BLM and INT by MAT and Coolant Temperatures. MAP kPa, Knock Retard Degrees and SA-TDC are also reported for each temperature range.
- Cruising (Constant Speed) Tab: BLM and INT according to MPH, MAP kPa, SA-TDC and TPS%. This Tab provides accurate data if MPH is held constant.
Version Updates
V11u 06/06/2017
- Minor changes to data presentation + faster calculation
V11i 12/21/2015
- Corrected divide by zero error if last log sample is the last sample completing an o2 data sample period as specified on the INPUT Tab
V11h 12/15/2015
- Additions to BLM and o2 Tabs
Initial Release v11b 10/15/2015
Have had requests for o2 data in the Analyzer, so decided to add it. But this version can only be used with Excel 2007 and higher. Also made several improvements to the prior version, one being that it now calculates 3 times faster. Virtually everything you would want to know about a log is provided.
V11u 06/06/2017
V11i 12/21/2015
V11h 12/15/2015
84Elky
22
01-10-2014 01:54 PM
