SAUJP v5 wide band
SAUJP v5 wide band
Hey Guys, just trying to set up for some wide band datalogging using SAUJP V5 and i noticed that when using the V5 xdf file that's included with the package i can no longer select the wideband input pin. there used to be an op2 bit 7 i think, where you could change it. I am using a 1227727 and because of the connectors i have the default pin is blocked off so i have to use the alternative C18 (A3) Was this option removed from v5 for a reason?
thx
thx
