Troubles saving VE tables with TUnerpro RT v5
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Anybody have troubles saving VE tables
I copy past from excel spreadsheet then spend another hour or so hand smoothing just to do it all over again
I can make changes and save other tables but not VE tables
I tried renaming bin also downloaded new Xdf file also still same thing
I tried pasting and then clicking another cell
Tried making single changes
Sigh lol
Sigh lol
Re: Troubles saving VE tables with TUnerpro RT v5
If I recall... TunerPro will make some changes too. Your numbers won't be exactly what you entered as the tool does some smoothing too. I've seen TunerPro move the advance 1/3 & 1/2 of a degree in the SA tables too.
What I would do... if it were me... is to SAVE THE HAND SMOOTH TABLES in excel until you've figured out the culprit.
TunerPro can be glitchy at times too. That's my experience.
So- when you say it throws out your hand smoothing- how much did you do? Was it less than a 1% difference?
If it was 1% or less, I wouldn't worry. If you run closed loop, the integrator would more than take care of it
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea that's what I noticed to just throw me off I started running lsx with hptuner so software is very different in easier good way but some glitches threw me off so I was like what the hell going on lol
That's what I started doing and did comparison of my VE maps and differences that TUnerpro makes changes is very minimal
Didn't realize till after I posted this thread and comparing them
TUnerpro does make slight changes to SA also
All changes i do I save to excel sheet
