code59.org issues? 383 stealth ram supercharged
Car: 1990 Trans Am GTA
Engine: 383 HSR Profiler heads
I'm putting a vortech on my 383 HSR and I want to run code on my 7730. I've been trying to register on code59.org so I can get some bins and info but I'm not getting a confirmation email to finish my registration.
Is anyone having the same problem?
Re: code59.org issues? 383 stealth ram supercharged
Anyone?
Or does anyone have bins or xdf files so i can start learning code59?
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea I had same problem just went to tunerpro and downloaded stock bin and went from there
I can send you files I have so you can get started but will need to do a lot of adjustments for your setup since you will flow a lot more in upper rpm
Go to gearhead efi forum a lot info and bins there
I gave up trying to register on code59
Ok glad to gear I'm not doing something wrong haha
What's your set up? It would be great to see a bin that already has some work done to it....I'm finding code59 kinda confusing
Engine: 305 to 350
Axle/Gears: 10 Bolt
355 vortec block
ported polish sportman 2 heads
comp cam specs I forget 218/220 iirc
eldebrock base, tpis large tube runners, 58mm tb all port match
full exhaust shorty headers dual cat 4" exhaust
im sure I missing little things here and there
Are you running boost?
Or are you just using code 59 N/A?
Engine: 305 to 350
Axle/Gears: 10 Bolt
no boost im not familiar with code59 I got bins from tunerpro site and all other files from another thirdgener but same files where on gearheadefi forum
never got a chance to log onto code59 they never sent registration code etc like you so I gave up on site and looked elsewhere
gearhead efi is really good forum
9192camaro
16
02-03-2019 12:21 AM
L98GTA87
08-11-2015 06:55 PM
