Inj PW Correction/Low Offset Bosch3 24
Car: check
Engine: check
Transmission: check
Re: Inj PW Correction/Low Offset Bosch3 24
Here is those injectors at 46 psi:
Injector Data Sheet: M-9593-AA302, 24 #/hr Bosch 3, 280-155-931
Fuel Pressure: 46 psi
Flow rate: 26.1 #/hr
Minimum PW @ 46 psi: 0.508
Offset Compensation versus Battery Voltage:
6.4 Volts: 2001 usec
8.0 Volts: 1385 usec
9.6 Volts: 1042 usec
11.2 Volts: 819 usec
12.8 Volts: 664 usec
14.4 Volts: 531 usec
15.0 Volts: 491 usec
Short PW Compensation versus Pulse Width:
0.015 msec: -213 usec
0.244 msec: -172 usec
0.488 msec: -129 usec
0.732 msec: -86 usec
0.976 msec: -43 usec
1.220 msec: -0 usec
1.460 msec: 0 usec
1.708 msec: 0 usec
1.950 msec: 0 usec
2.197 msec: 0 usec
2.440 msec: 0 usec
2.685 msec: 0 usec
2.929 msec: 0 usec
3.170 msec: 0 usec
3.410 msec: 0 usec
3.660 msec: 0 usec
3.900 msec: 0 usec
RBob.
1.220 msec: -0 usec
1.460 msec: 0 usec
1.708 msec: 0 usec
1.950 msec: 0 usec
2.197 msec: 0 usec
2.440 msec: 0 usec
2.685 msec: 0 usec
2.929 msec: 0 usec
3.170 msec: 0 usec
3.410 msec: 0 usec
3.660 msec: 0 usec
3.900 msec: 0 usec
RBob.
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
That's exactly what I need
Well I tried the chart I posted it really lean part throttle and wot quite a bit but I didn't touch looking at the wideband
Engine: 305 to 350
Axle/Gears: 10 Bolt
So for short PW just zero out table cause neg values don't save to table
Engine: 305 to 350
Axle/Gears: 10 Bolt
rb85TA
26
09-14-2015 10:29 PM
