ford red top 30# injector data
1 Post
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
does this look right for the ford red top 30# injectors?
19.60 0.6333
18.00 0.6333
16.00 0.6333
14.80 0.6333
14.40 0.6333
14.00 0.6344
13.60 0.6610
13.20 0.6877
13.00 0.7175
12.80 0.7690
12.40 0.8230
12.00 0.8854
11.60 0.9073
11.20 0.9312
11.00 0.9592
10.80 1.0850
10.40 1.2083
10.00 1.3405
9.60 1.4020
9.00 1.4667
9.00 1.5383
8.80 1.7087
8.40 1.8710
8.00 2.0394
7.60 2.3700
7.20 2.7000
7.00 3.0400
6.80 3.7900
6.40 4.2900
6.00 4.6800
5.50 7.0000
5.20 7.0000
4.80 7.0000
3.20 7.0000
1.60 7.0000
0.00 7.0000
also found this http://fordperformanceracingparts.co...-9593-b302.pdf
19.60 0.6333
18.00 0.6333
16.00 0.6333
14.80 0.6333
14.40 0.6333
14.00 0.6344
13.60 0.6610
13.20 0.6877
13.00 0.7175
12.80 0.7690
12.40 0.8230
12.00 0.8854
11.60 0.9073
11.20 0.9312
11.00 0.9592
10.80 1.0850
10.40 1.2083
10.00 1.3405
9.60 1.4020
9.00 1.4667
9.00 1.5383
8.80 1.7087
8.40 1.8710
8.00 2.0394
7.60 2.3700
7.20 2.7000
7.00 3.0400
6.80 3.7900
6.40 4.2900
6.00 4.6800
5.50 7.0000
5.20 7.0000
4.80 7.0000
3.20 7.0000
1.60 7.0000
0.00 7.0000
Re: ford red top 30# injector data
Wow! Sure u need that much injector? Or is this for some other motor?
Car: check
Engine: check
Transmission: check
This is what I have at 43 psi fuel pressure. Note that the 0 volt entry should be the same as the 12.8 volt entry value.
RBob.
Code:
Injector Data Sheet: M-9593-B302, 30 #/hr red tops, fat Fuel Pressure: 43 Flow rate: 31.3 #/hr Minimum PW @ 43 psi: 1.133 Offset Compensation versus Battery Voltage: 6.4 Volts: 2954 usec 8.0 Volts: 1749 usec 9.6 Volts: 1196 usec 11.2 Volts: 882 usec 12.8 Volts: 675 usec 14.4 Volts: 497 usec 15.0 Volts: 462 usec* Short PW Compensation versus Pulse Width: 0.015 msec: -146 usec 0.244 msec: -132 usec 0.488 msec: -117 usec 0.732 msec: -102 usec 0.976 msec: -88 usec 1.220 msec: -73 usec 1.460 msec: -58 usec 1.708 msec: -43 usec 1.950 msec: -29 usec 2.197 msec: -14 usec 2.440 msec: 0 usec 2.685 msec: 0 usec 2.929 msec: 0 usec 3.170 msec: 0 usec 3.410 msec: 0 usec 3.660 msec: 0 usec 3.900 msec: 0 usec
1 Post
Engine: forged 350
Thanks and I'm not sure what you mean do you mean for the Offset Compensation versus Battery Voltage at 0 Volts: should be 675 usec?
1 Post
Engine: forged 350
Well they are bigger then what I need figured they will be on a low dc and doing little work but I don't think they will be to big do you?
1 Post
Engine: forged 350
Ok makes sense. Why am I getting a error saying "could not write to change log file" when I hit commit changes?
Car: check
Engine: check
Transmission: check
Need to set TP to run as an Administrator. This part is O/S dependent. Try this: right click on the Desktop icon for Tuner Pro, if there is a line that states to run program as an administrator, click on it to set the check box as checked.
If not then select the Properties dialog. Look around for that same line and check it. IIRC, it is under the Compatibility tab.
RBob.
1 Post
Engine: forged 350
Ok found it but now it just resets all my changes to 0.00 after I hit commit changes. sorry for all the question's.
1 Post
Engine: forged 350
I don't understand should I be inputting the numbers differently then the way they are on the info you gave me?
Car: check
Engine: check
Transmission: check
Look at what the XDF file is expecting for the values. In your first post the values you listed are in milli-seconds. In my post I used micro-seconds.
RBob.
RBob.
1 Post
Engine: forged 350
I think I got it to except the values. does the small pw correction - port only need to be 0 for all values?
Car: check
Engine: check
Transmission: check
Good, they will change a little from the entered value. This is due to the 15.26 uSec resolution of the table.
Yes, all entries. I didn't realize that you are using an EBL system.
RBob.
RBob.
1 Post
Engine: forged 350
Oh yeah sorry ebl flash with port mod. Trying to get things ready for first start up anything else I need to set for the injectors? Thanks for the help rbob
1 Post
Engine: forged 350
Ok got the bpc vs vac set to 139. Not sure what to set the other tables to or where to find the info.
RBob.
Code:
Car: check
Engine: check
Transmission: check
You can't enter negative numbers is the short PW table. Enter those values are positive numbers and see how the tune works out. In the past I've always stated to zero out the short PW table. But try it with those values as a positive number.
RBob.
RBob.
ambainb
04-25-2016 09:21 PM
1992rs/ss
16
01-28-2016 09:58 PM
