Proms
Car: 1989 GTA
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Proms
First of all, please forgive my ignorance on this matter. I'm not a tuner, but would love to learn. My question is can a prom from a 305, 5 speed work on a 350 with the 700R4 ?
Thanks in advance.
Thanks in advance.
Car: check
Engine: check
Transmission: check
Re: Proms
Generally no, as there won't be TCC lockup logic invoked.
More importantly, it is more dependent upon what EFI system the engine has installed and which model year the PROMs are from. For example, take an '89 LB9 (305 TPI) and install it into the ECM of a '91 LB9 car.
Won't work even if they have the same transmission.
RBob.
RBob.
