8D_SAUJP V4A
1 Post
Car: BMW 735
Engine: 383 W/ SUPERAM
Axle/Gears: 3.64
8D_SAUJP V4A
I have been using 8Dmod, but wanted to try s_aujp v4. I burned a new chip, with the 41026 4a bin. I set the cylinder volume and injector size, entered in my initial timing (12 btdc). In the flags, word 1 bit 4, I unchecked the box in VATS. The car would not start. What is bit 6 used for? I am not using the ECM to turn on the fuel pump, should I set that bit? Are there any other initial changes I need to make?
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: 8D_SAUJP V4A
Bit 4 indicated to look for the VATS input or not.
Error word 3, bit 1 (VATS indication) should also be unchecked.
Disable the checksum with AA if your engine light came on.
Verify any error codes besides the normal "12" you may have and clear them before attempting to restart.
Jp
Jp
1 Post
Car: BMW 735
Axle/Gears: 3.64
Re: 8D_SAUJP V4A
Jp
Jp
ramicio
09-28-2015 01:18 PM
86TpiTransAm
01-26-2001 03:43 PM
