EBL WUD running on Windows 10?
Car: 1988 IROC-Z Convertable
Engine: 350 Cam, Heads, Heders...etc.
Transmission: 700-r4 "Raptor"
Hey all, does WUD run on Windows 10, I updated my laptop and now I cannot connect. Wast trying to chase down a fuel pump voltage problem that I think I traced to a bad connector at the fuel pump relay and now I cant see the data and its killing me... that and I need to get back to figuring out my idle stuff.
Thanks all
Thanks all
Car: 88 Iroc. 12.60@ 107. 1.72 60'
Engine: 350 paxton sn93 36lbs injectors
Axle/Gears: 9in. 390s
Re: EBL WUD running on Windows 10?
I wouldnt know. As i dont have EBL. But what i do know is you can get a cheap refurbished windows xp for like $100. Personally i like to have a laptop just solely for tuning, that way it dont get viruses and what not from being online because it can/ will effect the programs your running for your vehicle. viruses not only destroy the pc but when your talking blowing your motor. aint worth it.
Car: check
Engine: check
Transmission: check
May need to update the USB drivers. IIRC, WIN 10 uses a different driver for the FTDI based USB to serial adapters. But the WUD does run on it.
RBob.
RBob.
turbo z (09-04-2021)
cool i will look into it - I have plenty of laptops but they all went to windows 10 sigh.
the updated drivers did the trick, but for some reason usb 3.0 ports crash the system. Bumber because I liked seeing the tt1 and have the ebl up at the same time though not necessary. Thanks.
Damon
09-26-2015 04:29 PM
