False knocks
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
False knocks
Hi folks
Im running a EBL P4 its a great system. i do however have a problem with false knocks. I am thinking im going to swap knock sensors, as i understand it the LT4 sensor is less sensitive correct? I have searched and found old posts that state there is a knock sensor and a knock modual , could someone please explain the difference? part numbers?
from 3500 on up im getting a bunch of false knock ...i pulled 10 * and the knock is still there , so i assume its just false. thanks in advance for any and all replies.
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
Re: False knocks
You want the LT4 knock module.IIRC,the sensors are the same.The module is different.
Car: 1992 GTA
Engine: running
Axle/Gears: both
Re: False knocks
thx for the replies,
do you folks have the part number for the modual?
i just swapped a much tamer spark table in and did a quick test ... same kind of knock retard.. i want to swap moduals to see if it is truely false knock , thx
Re: False knocks
I'm not sure why the L98 5.7 knock sensor isn't working for you. Ironically, I'm running that very L98 sensor with LT4 spark table without any issues.
Unfortunately I don't the LT4 knock sensor p/n.
But if you go to http://parts-catalog.acdelco.com/cat...log_search.php you can probably navigate your way to it. Another good source would be gmpartsdirect.com.
Car: 1992 GTA
Engine: running
Axle/Gears: both
Re: False knocks
thx ... im going to check out the LT4 spark table, maybe mine is just too hot for the combo im running.
Car: 1992 GTA
Engine: running
Axle/Gears: both
Re: False knocks
Ultma8z ,
i dont have office to down load it, do you or anyone else, have a spark table from a LT4 that i just could insert into tuner pro , and give it a try? thx sean
87Formula4bbl
04-15-2003 01:27 PM
nsimmons
05-09-2002 06:49 PM
