windows 10 and tunerpro
have the tpi based swap in the duster, and its not firing the injectors. so I go to load up tunerpro rt and my aldl cable. cant get the laptop to recognize the cable.
what I'm using is an old aldl cable with a box labeled 10k, all from akmcables.com. have a seriel port to usb adapter that plugs into the usb ports on my laptop.
laptop is a brand new dell that I got about a month ago from bestbuy, loaded with windows 10.
fresh dowmload of tunerpro rt, fresh $8 .bin, .adx. and .xdf.
ecm is a 7727 ecm.
on my old laptop, I used the same stuff and had no problems ($a1 being the only difference).
so what do I need to do to get this thing talking to the ECM?
ecm is a 7727 ecm.
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: windows 10 and tunerpro
Also, make sure Turnerpro knows the correct com port that your cable is connected to.
327_TPI_77_Maro
02-22-2016 10:16 AM
