Cold start issue
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Cold start issue
I am currently running a modified '89 .bin in my '86 Trans Am. I'm not sure how the later MAF ECMs compensated for not having a 9th injector at start up. I have to use starting fluid to start the car when it's cold. Once it's started it runs fine. How do I get the needed fuel for a cold start?
Car: check
Engine: check
Transmission: check
Re: Cold start issue
Code:
;---------------------------------------------- ; CRANK PW vs COOLANT TEMP ; ; TBL = (msec * 256)/(SCALAR) ;---------------------------------------------- LC371 FDB 13108 ; 200.01, SCALAR FOR MAX PW ; CAL = SCALAR * 65.536 ; ; Msec deg c ;---------------------------------- LC373 FCB 205 ; -40 LC374 FCB 179 ; 140 -28 LC375 FCB 96 ; 75 -16 LC376 FCB 45 ; 35 -4 LC377 FCB 32 ; 25 8 LC378 FCB 20 ; 16 20 LC379 FCB 15 ; 12 32 LC37A FCB 10 ; 8 44 LC37B FCB 10 ; 8 56 LC37C FCB 10 ; 8 68 LC37D FCB 10 ; 8 80 LC37E FCB 10 ; 8 92 LC37F FCB 10 ; 8 104 LC380 FCB 10 ; 8 116
Thanks RBob!
