Trouble datalogging
Re: Trouble datalogging
I have the autoprom and am using tuner pro RT v5. I have a 92 camaro 3.1L automatic. I can connect through real time emulation... I can burn a chip... I can't datalog. I have tried many different adx files. I've attempted to use your $88 ads file on your site converted to adx file. I have attempted to add a "listen for silence" command and change the timeout from 0-10000. I continue to get the blue connected with a flashing DA: connection error. I can connect when I have it in the non-passthrough mode and the hz bounce around but it doesn't seem to be receiving any data. I have searched endlessly through thirdgen and gearhead efi with no improvement. Was wondering if anyone can offer any assistance.
Try this ADX http://scotthansen.net/$88.adx and call Dave at Moates if it still doesn't record. I built a page on how to use Tunerpro RT. Do you have the RT version? You can't record with just Tunerpro. See here http://scotthansen.net/data2
I am using RT and I have tried what you said on the site there. I am using the autoprom and when I set it to "Use Plug In" with the adx file you provided me it gives me the error I said about above. If I use imported adx file from the ads I got it just tries connecting for 30 seconds then stops. If I put it in autoprom mode it will say connected but doesn't see to be receiving data, just sits at 0hz. At one point I had it look like it connected and went up to .85 hz or something like that then the program crashed.
Is there anything cheap I can connect to see if it can scan my aldl comms
Dartht33bagger
30
08-14-2018 03:43 PM
oldmotorhead64
07-07-2016 08:43 PM
