keep blowing fuses?????
Old 04-17-2002, 07:56 PM
dana mickelson's Avatar
89 rs 305 tbi, the fuse for the door locks,lighter,horn,and courtiseylights keeps poping for no apperent reason also I've checked the Haynes manual for a wiring diagram all it has in it is the diagram for the door locks I'm not sure where to look for problem anybody else have this problem?
Old 04-17-2002, 08:12 PM
Nordbert's Avatar
Disconnect the wire to the LIGHTER! They break at the rear and ground to their housings. OR test from the center (hot) to the
housing with an ohm meter . It should read infinity. If the insides
are loose, it might get an intermittent short and blow the fuse.
3rd gen money
10-11-2019 09:57 PM
thunder57
11-07-2015 02:28 PM
Fanatic1074
10-02-2015 03:47 PM
lanceflame44
09-25-2015 12:28 PM
90formulaVortec
09-03-2015 09:26 AM
Quick Reply: keep blowing fuses?????
