What is it?????????????
Old 07-03-2001, 11:57 PM
82 cross fire's Avatar
I have an 82 Z 28 with the CFI under theh dash I found a little retuanguler box with three wires and inside is a small computer board. Well the board is cooked. All the books tell me is "To E Cell" What is that suposto be?? It also Says LU5 only of corse that realy limits the sources. Thanks For any help.
Old 07-04-2001, 04:33 AM
Jza
Jza's Avatar
What color is the box?
Old 07-04-2001, 04:37 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
"To E Cell" means you need to find Cell "E" in the wiring diagram for a better view. Where is the box located, what colors are the wires, how big is it, etc...
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old 07-05-2001, 04:14 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Light driver module, injector driver module?? Also, isn't the ECM in the center console in '82 models??
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
