has any 1 bought the kit for the distriburator were it......
bumps the timing up when u accelarate. if any 1 did this to there car. please post some feedback, if this sounds true what my freind told me then im gona buy 1
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Need more info... Don't all distributers advance in some way or another when you accelerate? I would say it sounds like BS because all distributers (within reason) should advance the timing when you accelerate if it is in proper working order... How far it advances should all depend on the base timing you set... don't go past 10 degrees base advance or you may have problems...
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear P215/60/R16, AIWA bargain basement (from Sears of course) CD player, Fuzzy dice, Eight-ball shift ****
Check out my ride here $1600!!
First Kill: 2002 Subaru Impreza WRX Wagon (1 person vs me with 2 passengers)
well my freind bought this kit were springs come and these metal pieces go inside the distriburator. theres 3 diff sets of springs. from light weight to heavy weight. heavy which would mean the best. i forget what the kit is called but its like 5 bux or somethin.
Car: 91 RS Convertible
Engine: 305 TBI
Well for starters I know nothing about distributors (but I'm lerning).
I do know how to look up parts though.
In summit they have part # SUM-G5212 which is a HEI Advance curve kit which sells for $4.50. It comes with 3 springs and a few other parts that go inside the ditributor.
The only thing is.....
It's for 74-79 non-computer controlled distributors.
I think the part you would need is made by Petronix. Part # PNX-D8000 that sells for $119.95. But this is an entire kit including rotor, cap, coil, etc..... and I'm not exactly sure if this is the correct part number for our distributors.
Also in JEGS they have the same kit as above made by Proform. Part Number 778-66945RC which sells for $75.99 and again has everything including cap and rotor.
Go to their websites and punch in those numbers and take a look.
I might be right , but more than likely I'm wrong.
thats it the curve kit. well i bought it and lol well i finaly found out that its for 74-79 cars . o well that sux. good thing i didnt open the pieces .i can return it atleast. i took my distriburator apart to pieces goodthing i knew how to put it back in
hectre13
12-11-2023 08:14 AM
86IROC112
09-07-2015 01:37 PM
