Digital Dashboard problem
Old 03-03-2003, 10:01 AM
RobBart98's Avatar
I have a 1984 Camaro Berlinetta and the Digital dashboard on it doesn't work right. But the gas gauge and the other gauges works fine but the speed and the RPM readout don't work and I am completely lost on how to fix it and what to do about it. Any input that I could get about it would help me out greatly.
Thanx Rob
Old 03-04-2003, 06:45 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You have a dead cluster,..........
The "digital" section of the system appears to be dead. I have NO idea how to repair it........ It's the most common reason for dash failures other than a bad printed circuit.
The reason that you still have normal working gauges is because the gauges are supplied with the power they need thru the printed circuit on the back of the cluster. ( & So is the "back lighting" behind those gauges.)
I have spare dashes for sale sometimes - so If you ever need one, just send me an E-mail and I'll let you know if any are availible.
P.S. BE SURE that you get the correct replacement for your berrlinetta !!! A V6 car needs a V6 cluster and a V8 car needs a V8 cluster !!
Old 03-10-2003, 09:19 AM
RobBart98's Avatar
Thanx for the info. My berlinetta is a V8 car and I would like to know if you do have any spare dashs around. That dash is one the only things that is keeping me from completing the car. You could E-mail me back at Bart98_2000@yahoo.com with your response that's the E-mail acount that I use the most! Thanx for your time and patience and also keep up the great work with the website I'm loving it!!!
Thanx again
Rob
Old 03-11-2003, 02:32 AM
blackknight2010's Avatar
Car: 85 Transam
Engine: 305v8 carburetted
The dreaded 84 berlinetta digital dash is well reknown for failing...mines did intermittantly, scrambled display etc. The other gauges are analogue hence the reason they work okay.
There was a guy who used to deal in digidash's for berlinettas in the U.S. but have no idea his web address. You could check via a search engine.
Old 03-21-2003, 09:30 AM
RobBart98's Avatar
Thanks for your input I really appreciate it. The digital part of this dash has NEVER worked as long as I have owned the car and I have the speeding tickets to prove it because I didn't have a clue at how fast I was going!! Go fiqure huh!!!! But thanks to this website I'm learning alot more about the car and I should have this dash problem fixed some I hope!! Thanx every1 who has helped out !!!
Rob
norcalz28
Northern California
26
12-07-2016 12:49 PM
middian
09-05-2015 01:42 AM
andy74
09-03-2015 08:41 AM
greenyone
09-02-2015 03:39 PM
masonta
09-01-2015 06:40 PM
Quick Reply: Digital Dashboard problem
