Part number for open IAT
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Does anyone know the part number for the open element IAT sensor?
This one:
http://www.diyautotune.com/catalog/o...tail-p-62.html
Or the application it came on?
This IAT outputs the same resistance as the stock TPI IAT, correct?
This one:
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You can try #TS83631 at Advance Auto Parts (PartsAmerica.com).
The application for this sensor is a V6 engine.
BTW, the stock TPI IAT sensor is not an IAT sensor in fact, it's just a plain ole' CTS. That would explain why the ECM sees "130 degrees" on a 60-degree day.
Lou
Lou
Car: '88 G T/A
Since this sensor will have different resistances at any given temperature then the stocker, will I need to re calibrate any parameters in the ECM?
Looking through the tables on my MAF car I dont see any tables that relate to intake air temperature. What does it affect?
Re: Part number for open IAT
Hi i just went through this today if you want an open type kragen has them as a bwd part#wt382 i believe its for a 90-91 vette you can use your same connector just have to trim the sides off with a razor blade hope this helps you IROCKMAN
1992 Trans Am
05-10-2023 07:19 PM
IrocZ'85
08-17-2015 06:24 PM
TA8487
08-16-2015 12:21 PM
