HOW TO REPLACE Ignition Lock/Keys Cylinder in 88 Camaro? HELP? - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 07-07-2007, 04:35 PM   #1
Car: 86 Camaro
Engine: 2.8L
Alright, I need to replace the ignition cylinder in this 88 camaro, anyone got a picture or a tutorial on this, modified wheel so it will come off real easy but otherwise, dont know steps i need to take to get the cover off where the cylnder is, or is there a tool to pull them out of the hole? thanks
Mike88z is offline vBGarage Page   Reply With Quote
Old 07-07-2007, 06:39 PM   #2
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: HOW TO REPLACE Ignition Lock/Keys Cylinder in 88 Camaro? HELP?
you are going to need 2 specialty tools well only 1 if your whell comes right off. it presses all the guts in to allow you to take off a lock ring on the shaft. once that is off http://www.autozone.com/az/cds/en_us...rInfoPages.htm
this link should get you trough the rest. Dont loose any screws down in the collumn and be gentle there is a lot of flimsy plastic that can break. Good luck.
Cooter
Just wondering, did your wife loose your key too?
cooter26 is offline vBGarage Page   Reply With Quote
Old 07-07-2007, 06:47 PM   #3
Kano_RS's Avatar
Perfect piece of information, My Ignition cylynder is stuck, i was looking for this information in other parts of the board,
Tnx a bunch
Kano_RS is offline vBGarage Page   Reply With Quote
Old 07-07-2007, 10:07 PM   #4
Before you go and yank out the gut's some words of advice.
I had a lock get stuck on me before and i went thru the entire process of pulling and swapping it for nothing.
It was a broken ignition switch which is on top of the colum toward the floor.
Just a handfull of screw's and total of 4 bolt's to find out.
Maybe take you 10 min's top once you get started, just take off the cover panel unbolt the 2 bolt's holding the colum up and you will see a rod going down to a white switch (well most of them are white) just unbolt the switch then try your key and see if it turn's.
Tobashadow is offline vBGarage Page   Reply With Quote
Old 07-08-2007, 04:48 PM   #5
Car: 86 Camaro
Engine: 2.8L
No, my problem is that the ignition has been broken, can be started with a screw driver or any key lol. The real issue is, the car was loosing all power, so I pulled the connectors that are on top of the column under the dash, all the wires rubbed off onto the metal and were catching a little spark/fire/smoke, so I replaced all the wires and this is what it is doing now:
when you turn the key on, usually the fuel pump goes on etc, right, well this one does nothing, turn the key a mm or so past on and hold it, power comes on, then same with starting, have to get it in the right spot to start, then you have to hold the key past the on position for it to stay running, otherwise, when you let the key go, you loose all power and the car dies. Sorry but I cant drive and hold a key on @ the same time.
Would the ignition cylinder cause this? 88 2.8L camaro
Thread Thread Starter Forum Replies Last Post
Hard Knocking back around the 6th Cylinder db057 Tech / General Engine 4 08-22-2015 09:17 PM
1992 Camaro at first barely runs, now doesnt at all 92camaroJoe Tech / General Engine 6 08-13-2015 07:07 AM
Need Help. Want To Purchase 1991 Camaro RS Zachattack0925 Tech / General Engine 2 08-12-2015 10:54 PM
Need Help. Want to Purchase 1991 Camaro RS Zachattack0925 Transmissions and Drivetrain 4 08-12-2015 10:52 PM
Full brake system... MustangEater82 Brakes 0 08-11-2015 08:52 AM
Go Back   Third Generation F-Body Message Boards >
Tags
86, 88, camaro, cylinder, fix, ignition, install, key, lock, remove, replace, replacement, replacing, stuck, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
