Auto-on headlights
Old 12-12-2007, 01:06 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Auto-on headlights
I want to have my headlights come on when I turn the key to any possition other then off. I also want the option of turning on the headlights on when the car is off. I was thinking a relay on the headlight wire with the ignition hooked up for the coil. this would make the lights stay on if I just left the switch pulled out. How could I make it so that the lights came on with the plunger in when the car is on. Diode somewhere maybe? thanks
Old 12-12-2007, 03:17 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Auto-on headlights
You want something like this....
http://www.treasurestate.com/diesel/accessories/drl.htm
I had a similar module in my previous car, should be available at your local parts store, that's where I got mine. Ask for a DRL (daytime running lights) module.
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
09-28-2015 11:55 AM
Quick Reply: Auto-on headlights
