89 tpi 350 wiring diagram? - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 03-07-2008, 02:39 PM   #1
I just bought a wrecked 1989 tpi camaro with a 350/700r in it.I am going to put the engine/transmission into a 1970 elcamino.
So here is my question....
Where can I find a diagram that will help me make the stock engine/ecu harness work as a stand alone that will be swapped into the elcamino??
I am proficient at wiring,but want a good write-up or diagram since the mitchel on demand one lacks in ease to read and follow.......
Thanks in advance and if this has been covered please direct me to a link and I will delete this thread.
Also is there any adverse effects of swapping a set of headers(with an o2 bung)and losing all of the air injedction???Things I should watch out for??
MRROCKAPE is offline vBGarage Page   Reply With Quote
Old 03-07-2008, 03:20 PM   #2
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: 89 tpi 350 wiring diagram?
All kinds TPI of info here: http://www.chevythunder.com
Good luck
Wadebryant is offline vBGarage Page   Reply With Quote
Old 03-08-2008, 11:04 AM   #3
Quote:
Good luck
Thanks thats a great resource!!!But does anyone have the pin-out for the drivers side firewall connector??Everything else looks plug and play.
Also where is a good resource for a speed sensor that goes in-line with the speedo cable at the transmission??
Last question....Am I gonna need to use a custom burned chip to eliminate the factory anti-theft??
Thread Thread Starter Forum Replies Last Post
Wont go into gearz. need help! camaro11j Transmissions and Drivetrain 2 07-08-2016 11:26 AM
307 TPI Jeep in Norway Caspar TPI 24 06-20-2016 12:19 AM
Bogging at 40mph need help!! Infested Tech / General Engine 2 08-14-2015 06:25 PM
350 carbureted to 305 tpi st.evel07 Engine Swap 5 08-13-2015 07:15 PM
[QC] 1990 TPI & T5 Engine Harness, PCM & PROM Sanjay Engine/Drivetrain/Suspension Parts for Sale 1 08-12-2015 04:41 PM
Go Back   Third Generation F-Body Message Boards >
Tags
1985, 350, 88, 89, diagram, diagrams, engin, engine, firebird, read, stand, tpi, wire, wireing, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
