horn blowing w/o touching horn button
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
everytime i push on steering wheel too hard (getting in or out of car) the horn blows.?
Car: 1984 camaro z28
Engine: L69 H.O
Re: horn blowing w/o touching horn button
mine did this my horn button was really loose i just bought a grant gt steering wheel and that seemed to fix it lol
sometimes the horn button becomes loose and shorts out, take off button and check to see that the terminal is tight or that nothing metal is touching the terminal or the base plate. I had a problem one time with mine the base plate came detached from the button, every movement sounded the horn.
sounds familar, sometimes they just become loose, take off the horn button and check to see if your terminal is tight, also make sure that the terminal isn't touching anything metal and that the base plate is tight, if the terminal or base plate is loose it will honk everytime it comes in contact with the metal.
Car: 89 Iroc Convertible
When my turn signal switch broke inside the column there was a piece of metal that contacted the horn terminals every time I turned the steering wheel.So basically my horn would go off everytime I made a turn.Man was that fun...lol
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
had that happen to me . remove horn pad , check all contacts . on mine the cheezy plastic weld had flaked away . the horn would blow when you pressed hard on the upper wheel . i thought that was normal , untill one morning at 3 am the horn went off by itself . good thing i live in the country , not too many neighbors heard it . check it out . good luck .
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
mine was blowing because the tilt become loose,and move so much that when i pushed on steering wheel it blew the horn i replaced colum and now its fixed.
