4th gen firebird security bypass?
Old 09-11-2008, 10:18 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
My friends has a 98 firebird wont start when she turns the key? Just gets the security light flashing.Engine wont turn over is there anyway to bypass this??Had a problem like this in my 89 formula.
thanks
Old 09-11-2008, 11:26 PM
theMAGICALheat's Avatar
Car: 96 Souped up Firebird, 89 KITT
Re: 4th gen firebird security bypass?
have they used a different key? Does the key have the 'computer chip' in it? if so, you may have to get in contact with the GM dealership to find what is wrong. Check the key chip and the inner vats too.
Old 09-12-2008, 09:02 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
she only has 1 key.i thought there was a way to bypass the relay?
Old 09-12-2008, 11:00 AM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
This article might help you out. You will have to determine which system is in the car and then go from there.
http://vats.likeabigdog.com/
Good Luck,
Corky
Casey Meyers
03-02-2016 10:46 AM
cam-mike
08-24-2015 07:23 AM
THABADGUY
Brakes
08-11-2015 03:43 AM
Quick Reply: 4th gen firebird security bypass?
