windshield wiper motor cover alignment
1 Post
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
how does the wiper motor cover align up? anyone know the trick to getting the wiper motor cover back on right?
why? got some bad advice that cover removal was necessary when changing washer pump, so took wiper motor cover off (removed 3 hex screws then took off cover). amazingly, its not an easy alignment. wipers worked perfect before but now just move 2 inches.
1 Post
Car: 87 Camaro Z-28
Re: windshield wiper motor cover alignment
1 Post
Car: 87 Camaro Z-28
bump - any ideas on this would be appreciated
Hi Scooter, I know it was a while ago but did you ever find out how to align the cover on your wiper motor. I have exactly the same prob. Would appreciate it. Regards Kevin
Thanks for your time but not sure this helps me. My motor has not moved from park, but on removing the plastic cover to rectify bad connections the blue plastic segment within the cover has got moved now where ever I put it wipers only move an inch or two. There is writing on the segment but doesn't make much sense to me.
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
