86' camaro horn wiring diagram.... - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 04-26-2009, 07:57 PM   #1
Car: 86' Camaro
Engine: 2.8L V6
Trying to find a wiring diagram for a 86 Camaro. I need to know the original routing for the horn from the steering wheel, all the way until it goes through the firewall. I have a Haines and oddly enough, there's every diagram except for that one.
griemar is offline vBGarage Page   Reply With Quote
Old 04-27-2009, 01:03 PM   #2
Car: 1986 Camaro Sport Coupe
Engine: 2.8L V6
Re: 86' camaro horn wiring diagram....
This at least shows how it's run. I wired in mine from it and it wasn't too difficult. It's from an 86 Sport Coupe...Hope this helps!
http://www.geocities.com/vtcamaro/Pi...rams/pg217.jpg
jaygod8 is offline vBGarage Page   Reply With Quote
Old 04-27-2009, 06:13 PM   #3
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
all i know is its the green one from the conn on the drivers side and runs up to the front fender where the horns are thats all i know good luck
tom86iroc is offline vBGarage Page   Reply With Quote
Old 04-27-2009, 06:19 PM   #4
Car: 86' Camaro
Engine: 2.8L V6
Thanks I apreciate it. Trying to hunt down a short that aparently is somewhere in the column. The horn is constantly "hot" and when I turn the wheel i can hear it making/breaking contact. Guess I'll just have to take the column apart this weekend and see if I find anything.
I knew this car was going to be a project, this is what I get for spending only $500 on it, LOL.
Old 04-29-2009, 06:45 PM   #5
tom86iroc's Avatar
Car: 1986 iroc
yeah sound like a bare wire in there good luck
Old 04-15-2011, 05:02 AM   #6
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
^^ been there almost done with that. i know how you feel.
jeff_blake is offline vBGarage Page   Reply With Quote
Old 04-15-2011, 03:30 PM   #7
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There's a horn relay in there somewhere as well.
Here's a wiring diag: http://92b4crs.tripod.com/86wiring/dia-pics/40-0.jpg
Here's the other diags for a 1986: http://92b4crs.tripod.com/86wiring/86wiringindex.html
camaronewbie is offline vBGarage Page   Reply With Quote
Old 08-18-2012, 03:33 PM   #8
JDud's Avatar
Thanks for the info....
JDud is offline vBGarage Page   Reply With Quote
Thread Thread Starter Forum Replies Last Post
adding underhood light to Trans Am TheJoeY88 Electronics 19 12-31-2016 08:30 PM
91 Camaro intellitronix gauge install rocn7roc Electronics 8 12-10-2016 10:34 AM
307 TPI Jeep in Norway Caspar TPI 24 06-20-2016 12:19 AM
Need Help. Want to Purchase 1991 Camaro RS Zachattack0925 Transmissions and Drivetrain 4 08-12-2015 10:52 PM
Fuse for steering wheel controls? 88 gta Keiffer76 Car Audio 4 08-10-2015 12:37 AM
Go Back   Third Generation F-Body Message Boards >
Tags
1984, 1985, 1986, 1990, 86, 92, camaro, diagram, gen, horn, iroc, location, repair, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
