voltage gauge
Old 05-23-2009, 11:49 AM
edeyethejedi's Avatar
Car: 1989 RS Camaro
voltage gauge
The gauge jumps from 10 - 13, not steady for long periods of time. All connections at cluster check out okay. Alt. has been replaced, grounds have been checked, 13.8v at battery. Connectors have been cleaned, new battery cables. Any ideas on how to keep my gauge at 13, or does it just go down when the battery is at full charge.
Thanks,
Eddie
Old 05-23-2009, 12:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: voltage gauge
is this at idle or always?
Old 05-23-2009, 03:24 PM
Car: 1989 RS Camaro
Re: voltage gauge
always. Some days it stays on 13v but other times it fluctuates from 10-13 don't know if it matters, it's a 89 rs Camaro 305 tbi
Eddie
Old 05-23-2009, 03:39 PM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
Re: voltage gauge
My friends car (89 RS, 305tbi iroically) does the exact same too.
But its alot more heavy liek 10-16 volts. it fluctuates. and it really does, its not the gauge. cuz the lights dim and everything.
Old 05-23-2009, 09:58 PM
Car: 1989 RS Camaro
Re: voltage gauge
I may have found my problem. The printed circuits for the instrument panels (part #25081605) is partially corroded green. found the part at classic industries for 70.00, so I may try this and hope for the best.
Eddie
KCG
06-24-2020 04:33 AM
Elephantismo
02-13-2019 12:51 AM
327IROC85
09-23-2015 12:11 AM
eustodp
09-20-2015 05:09 PM
ULTM8Z
09-16-2015 09:15 AM
Quick Reply: voltage gauge
