fog lights
Old 07-05-2009, 12:05 AM
irocboy8292's Avatar
Car: 1986 Camaro Z-28
Engine: 3970010--5.?l
fog lights
hi i got a 86 z28 and my fog lights stopped working a while back so i bought the bulbs today thinking it was that and nothing they dont work i heard there is a relay and fuse but i dont know the location... i was also told it could be the switch is there any way of testing where the problem is coming from? also the location of both the fuse and relay?
thanks for the help
Old 07-05-2009, 03:01 PM
Re: fog lights
bump
Old 07-08-2009, 12:06 AM
Re: fog lights
any one?
Old 07-08-2009, 12:29 AM
Gothic_Rocker's Avatar
Car: 1991 Camaro Z28
Engine: 350 T.P.I
Re: fog lights
i would say get a test light and try seeing if your getting any power to the lights themselves mine did that but i went out and baught new L.E.D lights for it
Old 07-09-2009, 01:35 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
HURRY - THE FOG IS ROLLING IN
The fuse is labeled FOG LPS and is located in the block where the other fuses are, on the lower right portion of the block.
The block is located in the knee bolster door.
There is a relay. It’s located to the left of the fuse block.
You’ll probably have to remove the bolster to gain access.
To use the fog lights you must have the marker lights on.
A quick (but not all inclusive) test of the switch is to remove the bolster and cycle the switch and listen for the relay.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old 07-09-2009, 09:23 PM
Billy_Bob's Avatar
Car: 92 GMC Sierra 2500
Engine: 5.7l
Transmission: 4L70
Axle/Gears: GT4 3.73
Re: fog lights
Because the wiring in vehicles is all wrapped up in bundles and frequently inaccessible, it is a WHOLE lot easier to troubleshoot electrical problems using a factory electrical manual.
Sometimes this is a separate book from the factory service manual. Sometimes it is a part of the factory service manual set of 3 or 4 books. These show everything on the circuit including relays, show fuses and what all is on each circuit or which fuses are for a particular circuit, locations of wiring, locations of connectors and devices, and wire colors and pin outs for connectors.
You can order a factory service manual set which should include the wiring diagrams from your dealer or here...
http://www.helminc.com
Old 08-23-2011, 04:59 PM
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
Re: HURRY - THE FOG IS ROLLING IN
Happy Racing!
I got the same problem just got used fog and put blubs I getting no power on fog lights fuse 30A/ 12V check all the plastic fuse except the two metal fuses there both 30A and cant tell if there good thanks
skeltor
02-02-2016 10:37 AM
florida_gators
Exterior Parts Wanted
09-07-2015 07:19 PM
flash2042
Interior Parts Wanted
09-07-2015 07:15 PM
Ian Irvine
09-04-2015 08:08 AM
luvofjah
09-03-2015 07:08 PM
Quick Reply: fog lights
