electronic speedo to cable speedo?
Old 10-12-2013, 01:29 PM
  #51
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: electronic speedo to cable speedo?
I don't know Firebirds that well but you could either try swapping the speedometer unit from the cluster (if they are similar) into the new one, or get a hold of the transmission sender and wiring from the donor car (as mentioned above), or from one of the similar year.
I'm thinking that your original cable driven speedometer won't be affected by the electronics, plus your mileage on the odo will be correct. One thing that you might notice with the new cluster is that some of the engine warning lights etc. may not match. They may either light up incorrectly or not at all, and IIRC the the manual clusters have an up-shift indicator.
Old 10-24-2014, 07:20 PM
  #52
Zeromitch87's Avatar
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
bringing this dead thread back to life, i hope. I have a 1987 GTA with the digital dash and it works 100% I just have a few questions.
I am upgrading to the 4L60E transmission using a stand alone computer for tranny and my transmission guy has done it on 3rd gens b4 but he isn't sure about the digital dash for getting the speedo to work on my application due to digital dash and him being 2 states away.
He spoke to a person at http://www.abbott-tach.com/Welcome.html
and they have a solution but he isn't sure if its cable driven or digital due to this "rare" dash. They have a adapter that suppose to plug in behind the cluster and plug in to the transmission or something of that nature.
Can you guys tell me some more info about how this speedo system works in my car so i can order the right part.
Mitch
Old 10-24-2014, 08:25 PM
  #53
Scorpner's Avatar
Engine: V6, V8
You should be able to look at your car to verify that you have electronic wiring and not a mechanical cable at the transmission. On one the sensor is at the transmission and the other the sensor is at the cluster.
Your builder should also be able to tell you if you can re-use your original sensor from the 700r4 in the 4L60E. And IMO it would be best if you can use your original sensor for your cluster.
Edit: Here's a mechanical cable:
http://i.ebayimg.com/00/s/MzAwWDQwMA...JzQ~~60_35.JPG
And this electronic:
http://www.wwdsltd.com/files/TAVSSLocation.jpg
The above is from this thread:
https://www.thirdgen.org/forums/elec...le-speedo.html
Old 10-24-2014, 09:08 PM
  #54
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Well I'll find out tomorrow when I'm ripping out the puny 350 and 700r4 and I'll take a look at it.
I wonder if the old sensor would work, I know the two transmissions pretty much look the same minus internals. I won't know until the transmission gets here and I plug and play with it.
Thanks for your advice.
Old 10-24-2014, 09:20 PM
  #55
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Originally Posted by The above is from this thread:
[URL
https://www.thirdgen.org/forums/electronics/540712-electronic-speedo-cable-speedo.html[/url]
That is this thread
Old 10-24-2014, 09:22 PM
  #56
Scorpner's Avatar
Engine: V6, V8
You're welcome. I'm not sure about the sensor either, I agree that they are very similar which is why I was thinking about it. Make sure to ask your builder if it would work or not.
Old 10-24-2014, 09:25 PM
  #57
Scorpner's Avatar
Engine: V6, V8
Originally Posted by Zeromitch87
That is this thread
Oh it is! I searched google for a sample pic and didn't realize it was the same.
Old 10-24-2014, 10:04 PM
  #58
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
no problem you made good effort to search and try to help me.
Old 10-25-2014, 10:09 AM
  #59
Scorpner's Avatar
Engine: V6, V8
Thanks!
Old 08-21-2015, 04:15 AM
  #60
andrew1980's Avatar
I put a 1983 2.8 v6 motor and a 85 transmission in 1997 s10 how can I get the speedometer to work also hadthe gas gauge working then it quit then started to work again but didn't read right then stopped again any body have any idea.
InfernalVortex
04-20-2021 11:31 AM
armybyrd
Carburetors
10-20-2015 03:57 AM
TMZIrocZ350
10-07-2015 12:09 PM
rs_z28_vert
09-30-2015 09:47 PM
anesthes
09-30-2015 07:48 AM
Quick Reply: electronic speedo to cable speedo?
