1982-1986 firebird headlight relay wiring
Old 12-23-2009, 03:56 PM
sflthndrckn's Avatar
Hey everybody im hunting down a problem with my passenger side headlight only going down but not up. anyway i got a new relay and redid the wiring for it. Just in case anyone ever needs it here is a diagram for the location of the wires (by color) to the relay.
Old 12-25-2009, 02:14 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: 1982-1986 firebird headlight relay wiring
I'll check my shop manual and see if I can shed some light on this.
Old 12-31-2009, 09:57 PM
hotbird89's Avatar
Car: 90 Trans Am
Engine: 5.0 TPI- slightly modified...
Transmission: Modified 700-R4
Axle/Gears: 10 bolt 3.23 eaton posi moser shaft
I have a few questions...
What year is the car?
Have you checked the connector at the motor for corrosion? (my passenger side did the same thing- serious corrosion issues...)
Have you checked the headlamp module? That is what controls the operation of the headlights...
Old 01-01-2010, 10:57 AM
uemf's Avatar
Car: '86 Firebird
Engine: '85 TPI on crate 350
Transmission: T-5 man
82 - 86 no module... just three relays.
Old 01-01-2010, 11:36 AM
Drew's Avatar
Received 1,052 Likes on 748 Posts
-deleted
Old 01-03-2010, 07:20 AM
thanks alot for all your help guys. iv been super busy with work lately but ill take a look at the things you suggested whenever i do.
BRoss99
12-07-2020 06:50 PM
Glowsock
08-02-2020 07:36 PM
Caspar
06-19-2016 11:19 PM
pigpete
Exterior Parts Wanted
08-15-2015 07:56 AM
Quick Reply: 1982-1986 firebird headlight relay wiring
