No Instrument panel lights
Car: 87 Pontiac TA
Engine: 5.0
Transmission: Automatic
Let me know if you have any sugestions, on my 1987 T/A my instrument lights went out. I have checked the fuses and they are all good.
I removed the cluster and replaced it with known good one, I still have no lights. I also lost my fog lights at the same time.
Louie
Louie
Re: No Instrument panel lights
Is your headlight/dimmer switch good? That would be the first thing I'd check if you've got good fuses.
1 Post
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Sounds like a Ground problem to me. Check the Ground wire.
Ghettobird52
12-29-2023 08:23 AM
