Vats bypass chip?
Car: 1992 RS
Engine: 3.1L MPI V6
Vats bypass chip?
does anyone know were to get one
it plugs into the pcm and deletes the vats?
I have a 92 camaro rs and ive lost my keys
ive swap out the ignition cylinder and now need to do a bypass
and i just dont understand how to do the resistor bypass
i know its easy but i dont trust myself doing it
my cars been siting for little over a year with this problem
if anyone can help it will be greatly appreciated
Troy
Troy
Re: Vats bypass chip?
wel first you need to know the original resistor value of your car.
I think there where 15 diffirent value's
In Kilo ohms
1覧覧 0.402
2覧覧 0.523
3覧覧 0.681
4覧覧-0.887
5覧覧-1.130
6覧覧-1.470
7覧覧-1.870
8覧覧-2.370
9覧覧-3.010
10覧覧3.740
11覧覧4.750
12覧覧6.040
13覧覧7.500
14覧覧9.530
15覧覧11.801
anyway, search under your dash for 2 thin white wires in an orange tube ( I thought )
it will have a connector in it somehwere, disconnect this connector.
now you can cut of the side of the connector that goes 2 the sterringwheel, take this part to your workdesk. and solder the right resistor between those 2 white wires.
plug in the new connector you just made with the resistor, and put your key in the On position. if you used the right resistor value the security light should go out again.
of its not right its 1 of the other 15 value's and you should use another resistor.
In Kilo ohms
1覧覧 0.402
2覧覧 0.523
3覧覧 0.681
4覧覧-0.887
5覧覧-1.130
6覧覧-1.470
7覧覧-1.870
8覧覧-2.370
9覧覧-3.010
10覧覧3.740
11覧覧4.750
12覧覧6.040
13覧覧7.500
14覧覧9.530
15覧覧11.801
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Need to manually bypass the starter enable relay that was controlled by VATS module ;as above unit only supplies the correct signal to the ECM for the injectors
Car: 92 Camaro RS T-Top
Engine: 3.1 V6
Transmission: 4 Speed auto (standard)
Axle/Gears: Standard
I found this on eBay. It may be the easiest solution:
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Car: 82 Z28
Transmission: T400
http://www.pcmforless.com/index.php?...id=2&Itemid=43
Can get other changes done at same time / cost.
Change fan operating temps , delete emissions , change torque convertor lock up
Anything that is shown in the order sheet list above
Car: 1984 z28/1991 rs/1986 trans am
Engine: 84 5.7/91 3.1/86 5.0
Transmission: th 350/t5/700r4
any one no were to get blank chiped keys so i can have back up set of keys thanks for any help
need help trying to find keys like this that just need to be cut look like this
Car: 16 Equinox,12 Silverado,91 Z28
Engine: 3.6l, 5.3l, 305 H.O.
Transmission: 6 Spd auto, 6 Spd Auto, 4 spd Auto
I bought keys from this company. If you don't know which key you need, you can mail your key to them. They will decide which key you need and send it to you.
http://myworld.ebay.com/ebaymotors/carlocksandkeys/
