tach does not work
Old 02-16-2011, 12:59 AM
monsterjam5000's Avatar
tach does not work
my tach does not work and i was wondering if some one here knew what wire under the dash went to the tach.
cars a 1991 firebird formula
Old 02-19-2011, 09:37 PM
Re: tach does not work
any body?
no body knows what wire is the tach wire.
Old 02-19-2011, 11:16 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
check to make sure all of the wires are connected to the distributor.
Old 02-20-2011, 05:15 PM
all the wiring is gone. it was cut out during the motor swap so i have to splice in under the dash.
Old 02-21-2011, 08:50 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
A Tach The Problem
The tach wire goes from the PRIMARY non-key side of the coil, to the firewall connector, to the dash connector, to the tach.
At the dash the tach wire is in the right hand connector, pin 7.
If the original is still there it’s a WHITE wire.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Jeremys87
07-14-2022 09:08 PM
eightsixseven
08-14-2015 03:09 PM
mustangman65_79
08-07-2015 09:41 PM
stalkier
08-07-2015 04:49 AM
Quick Reply: tach does not work
