Wiring in a start button...
Car: '84 sport coupe
Engine: 355 .030 over 202 heads cam from RV
Axle/Gears: Idk, re is out of 93-97 V8
OK here goes. So I would like to wire in a push start button. The way I'd like to do this is so that you have to have the keys in the ignition, in the ignition position (for security reasons) but then you use the push start to crank. Does anyone know what wire in the existing ignition switch that I need to tap into? I Have an '84 sport coupe if that helps. Thanks!
Car: SOLD!!!!!
Re: Wiring in a start button...
just cut in the purple wire in this schematic. the key would still have to be inserted and turned on.
http://www.austinthirdgen.org/mkport...ine_wiring.gif
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
for engine to crank over
Need to jumper from the RUN terminal to the START terminal ( yellow wire ) at Ign Switch 1st,
then install a push button on wiring to starter
That way power is always available to the push button when Ign turned on and push button is dead when Ign turned off
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Post # 17 in this thread:
https://www.thirdgen.org/forums/elec...ush-start.html
has the wiring diagram you need. It shows how I wired my starter button in. You have to have the key in the ignition and turned to RUN in order to start the car. I will eventually eliminate the key itself, just haven't quite decided how I want to do that yet.
Car: 82 Z28
Transmission: T400
On a 84 he needs to jump the starter wire at the Ign switch as shown below.
Push button can then be installed anywhere down stream before starter;
on either the purple or yellow wires
Car: 91 RS
Engine: 305 TBI
Transmission: 700R4 shift kit vette servo
Axle/Gears: 3.73 Eaton Posi
has the wiring diagram you need. It shows how I wired my starter button in. You have to have the key in the ignition and turned to RUN in order to start the car. I will eventually eliminated the key itself, just haven't quite decided how I want to do that yet.
When you figure out how your going to do it you gotta up date me I want to eliminate the key completely as well!!
Car: 1992 Camaro RS
Don't worry, I'll be posting up a build thread showing what I did and how I did it. It's way down on the list of mods though, so it will be a while till I get around to it.
