Wiring diagrams
#51
Re: Wiring diagrams
Oil pressure was generally tan or brown. Green would be coolant gauge sender.
#52
Car: 82 Camaro Z28
Transmission: auto
Re: Wiring diagrams
got those wiring pics up on Em's site 7 pics = 2 hrs of life. I think i'll just email them to him next time
#53
Re: Wiring diagrams
I finally figured out how to post them with minimal pain. Need to get back to it though. Alot left to do.
#54
Car: '83 Z/28
Engine: 350 TBI waiting to be test fired
Transmission: Stock 700R4 with TCC switch
Axle/Gears: 3.23 non posi
Re: Wiring diagrams
Ok yes the oil pressure is tan, I checked the wire diagram I have. This green wire with 8 volts going thru it has a female "spatula" connector on it for lack of the proper name for that style of connector. Its the same as the green wire thats on the window motor for the wiper "pulse" but this has to be a sensor wire or something. Could it be tachometer then?
#55
Car: '83 Z/28
Re: Wiring diagrams
Chevy G20 vans dont have stock tachometers so thats not included into the diagram, the diagrams for the 83 Camaro, at least the ones I have dont show me the tachometer sensor wire :/ The new oil pressure sender and coolant senders have 2 wires instead of the single wire the original 305 had. Its just coolant and oil pressure that I need to figure out, Ive been taking a break since Im out of cash at the moment to get a few last parts before I try to fire the engine.
#56
Re: Wiring diagrams
You need to get the correct sending units. The oil pressure sender for the gauge will have one terminal. As will the coolant temp sender. Do not confuse the oil pressure sender with the oil pressure fuel pump switch which has two connectors. Also, don't confuse the oil pressure gauge sender whcih has one terminal and threads into the left cylinder head, with the CTS for the ECM which has two terminals and threads into the front of the intake manifold. The green wire with the "spatula" connector is to the coolant temp sender.
#57
Re: Wiring diagrams
Code 32 description and diagnostics:
#59
Re: Wiring diagrams
You convert it to jpg. and black and white to reduce the bit size of the pages and upload it to the link above at EagleMark.com DIY EFI. They are hosting the library for us. Youll see my 87 Camaro uploads. I'm about half way through the Electrical Diagnosis Suppliment.
#60
Re: Wiring diagrams
Okay I will do that when I get home..currently away
#62
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
Re: Wiring diagrams
Can you give me direct link to where these scans are being kept? I can't find nothing on the eagle-mark site.
#63
Re: Wiring diagrams
All those diagrams ASE Doc uploaded are at:
http://gearhead-efi.com/gearhead-efi/wiring/
#64
Re: Wiring diagrams
Thanks Eaglemark for staying on top of this thread. I started back to work in April and haven't done anything on this project since. Still have more useful diagrams to upload. I think with what you already had, we've compiled a pretty good set already.
#65
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Wiring diagrams
#66
Re: Wiring diagrams
There's no photo gallery anymore. Everything is split up to ECM specific threads. Members can have their own photo albums that can be public or private. Stuff that is not specific to ECM/PCM was just left there for you. I can upload anything you want to share there?
If you want it in some kind of specific order your welcome to start a thread? I think you could do the same here but the size of a wiring diagram would have to be zipped here. I try to keep all options open for useful size diagrams without zipping. Then there's copyright issues... so it's hard to share them openly. Most of them were Camaro specific which should be here, ECM/PCM specific is what GearHead-EFI.com is for sharing.
I offered a place for ASE Doc to put them and the offer is still there.
#67
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Re: Wiring diagrams
Great Find! I'll make sure to use this in my wiring re-build.
#68
Re: Wiring diagrams
How do I get you then 87/88 Firebird Service manual...its compressed to a rar file but its still 99 meg
#70
Re: Wiring diagrams
If there is any one general statement I can make with absolute certainty with regards to automotive wiring it is: PURCHASE A GOOD SOLDERING GUN AND LEARN HOW TO USE IT. Cover all soldered splices with marine grade heat shrink tubing. The marine grade heat shrink is coated inside with a hot melt sealer that makes the joint weather tight. Crimp connectors are not suitable for long term repairs and will almost certainly assure you of future electrical failures. If you have built your harness using many of these connectors, you will have a difficult time tracking down these future issues. If you must use crimp connectors in some part of your harness, spend the extra money for the type with heat shrink covering and use a heat gun to seal them. Also, a good set of crimpers, such as "Kline" brand are a necessity.
#71
Re: Wiring diagrams
http://www.filesonic.com/file/u20Jxdy
Here is the uploaded link...let me know if this works. Its in a rar format
Glowsock
01-09-2017 04:06 PM
