alternator question
Old 08-03-2011, 02:29 PM
andresinibus's Avatar
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
alternator question
Hi guys well im doing a single belt set up on my 85 from an 92 no my question its how am i supposed to wire the alternator since my current one its the 2 wire one and the new one its the 3 or 4 wire one how to wire it? any imput appreciated
Old 08-03-2011, 07:51 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: alternator question
You realize to do this swap, you'll have to change the alternator (as you already know), the water pump (to a reverse flow), AND the PS pump as well, right? NONE of the non-serp accessories have the same bolt holes as the serp accessories.
Old 08-04-2011, 03:47 AM
thanks for the heads up on the water pump im using the aluminum brakets im guessing the pump is still required any input as far as how to wire the alternator what wires am i supposed to connect to which move redirect or eliminate thanks again
Old 08-04-2011, 06:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by andresinibus
my question its how am i supposed to wire the alternator since my current one its the 2 wire one and the new one its the 3 or 4 wire one....
http://paceperformance.com/p-3980-se...nnections.html
JamesC
Cornholio7979
09-20-2018 02:31 AM
dutch930
09-11-2015 06:58 AM
Cleotiz
08-23-2015 12:07 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: alternator question
