Brake lights out
Old 08-22-2011, 08:31 PM
Deck man's Avatar
Car: 91 RS
Engine: 5 liter
Brake lights out
I found out today by a passing motorist that I didn't have any brake lights. The tail lights, turn signals work but not the brake lights including the high light. I checked the fuses and they all look fine. Need some guidance on where to look next.
Old 08-22-2011, 08:36 PM
GShipp85Trans's Avatar
Car: 1985 Pontiac Firebird TransAm
Re: Brake lights out
i am having the same problem, i think its something in the wiring but iv checked the wires i can get too and there fine so i cant figure out whats wrong
Old 08-22-2011, 08:44 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
The brake switch is located on the brake pedal. Check for 12v at fuse, and keep checking the circuit until you find the break in it.
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Bad brake light switch could be the culprit. Check the bulbs as well.
Old 08-22-2011, 08:52 PM
Deck man's Avatar
Car: 91 RS
Engine: 5 liter
where is the switch located? Is it up high. I did a little poking around but didn't really crawl underneath the dash.
Old 08-22-2011, 09:06 PM
right behind the brake pedel. its white/beige i believe. Its mounted to a bracket off the steering column if i remember correctly. Each time the pedal is pushed, it pushes a rod into the switch completing the circuit turnign the lights on.
Old 08-22-2011, 10:42 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
just some info, the brake light power after it leaves the pedal switch goes up through the turn/hazard switch before it gets to the brakelights.(the third does not)
a bad turn/hazard multifunction will kill your brake lights,but the third brake light will still work.
(BUT NOT ON THE CAMARO) on a firebird it will.
Old 08-22-2011, 11:40 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That might be true if the rear turn signals used the same bulbs as the brake lights. The OP's profile shows 91 Camaro RS, which has a separate circuit fo the brake lights and turn signals. Check the wiring diagram here..
http://www.austinthirdgen.org/mkport...ody_wiring.gif
Looking through the list of wiring diagrams by year, the Trans Am through 89, and all others through 85 have the brake light power go through the hazard switch.
http://www.austinthirdgen.org/index.php?pid=19
Old 08-22-2011, 11:50 PM
regal301's Avatar
Car: 1988 iroc-z
no...... i know,it slipped past me, i have a pontiac,and the camaro is one of the few that have seperate turn lamps from the brake lamps.
the multi switch is common on the caprice,blazers,berettas,etc.(the camaro is an exception)
good catch
Old 05-17-2016, 09:19 PM
Darlene Green's Avatar
I have a 89 camaro iroc z28...brake lights wont come on...have replaced brake switch, bulbs, fuses....please help....desperate!!
Old 05-17-2016, 09:32 PM
Car: 91 z28
Transmission: 4L60e
post #3, is there 12+ volts at the fuse?
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
Old 04-03-2017, 04:42 PM
tillyvick14's Avatar
I just started having trouble with my brake lights (all of them including the high light) on my 91 firebird. If I cycle the hazard lights on and then off it seems to make the brake lights start working again for a short time. Does this help to find the problem? Thanks for any help you might have!
Old 04-04-2019, 10:29 PM
69pony's Avatar
Having a similar problem with my 88 formula. The brake lights and turn signal lights are on a different fuse. I have no brake lights or hazzard. The fuse was MELTED so not sure what happened.
Replaced the fuse and did not fix problem. I pulled one brake light and it was burned out. Replaced it and nothing. New fuse did not blow. I will check/replace hazzard blinker tomorrow. I just had the darn thing inspected Tuesday and everything was fine.
Old 04-29-2019, 04:56 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Brake Break
Wire a small spare bulb such as a side marker.
Connect one lead to ground, the other lead to the
orange wire coming out of the STOP HAZ fuse.
If the circuit is good the lamp will stay lit.
Connect another spare bulb from ground to the
light blue wire coming out of the brake light switch.
If the circuit is good the lamp will light when you hit the brakes.
If the 2nd spare bulb ever fails to light, observe the first spare bulb.
If the first bulb is out, try the hazard trick and report.
Happy Racing !
Funny Car Fun Fact: Funnys reach over 300 miles per hour before you have read this sentence.
wbrooks63
Exterior Parts Wanted
10-04-2015 08:40 PM
SpaniardV6
Brakes
19
09-07-2015 03:04 AM
stalkier
08-21-2015 01:54 AM
stalkier
08-13-2015 12:59 PM
Omega
08-10-2015 12:46 PM
Quick Reply: Brake lights out
