86 Camaro Gauge Cluster Pinouts Inside
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Trying to wire up a 98 TA cluster with my ls1 swap, and needed to figure out the pinouts to my stock gauge cluster. So heres what I came up with using Austinthirgen.org
If anyone can help Ive got a few wires that I couldnt figure out:
Passenger side C1
- Two brown wires feed into pin 8. Why is there two, and whats it for?
- Pin 9 is BLK/WHT on my car, but comes up BLK on the wiring diagrams and as a ground. Still a ground?
Drivers side C2
- GRY wire feeds into pin 3, couldnt trace?
- Two DK GRN wires feed into pin 7. I know what there for but why two wires?
- GRY wire feeds into pin 11, couldnt trace?
- GRY wire feeds into pin 12, couldnt trace?
Edit:
Well after searching some more; The 87 cluster pinouts, passenger pins 8 and 9 are buffer signal and buffer ground respectively. And the GRY wires on the drivers side are listed as illumination. So Im guessing 86 and 87 are similar.
Pinout Updated
Any help would be greatly appreciated. Thanks
Passenger side C1
Drivers side C2
Edit:
Pinout Updated
