help. blowing ecm fuse
Car: 1988 Camaro Iroc-Z
Engine: 1994-1995 LT1 5.7
My 89 tbi camaro is blowing the ecm fuse at key on position. Followed orange wire to passenger side fender to a splliter ( two orange wires to oil pressure and fuel pump relay. And to that ecm fuse. Two wires from that 5 wire coupling go to the ecm under the passanger dash. Orange wire looks good. What else should I inspect that could cause the ecumenical to blow?
1 Post
Car: 1991 RS
Re: help. blowing ecm fuse
Check for a short on all the power pins on your ECU. Also check for a short with any components also on the same circuit with that fuse.
Decided to take off the wiring behind the dash and relocate it to the trunk. Fuse box
gta892000
09-16-2015 12:37 AM
