Cluster swap help
Old 03-03-2012, 03:24 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
Cluster swap help
I know there are planty of threads somewhere on this but I'm having issues with finding them, plus I just want to hear it straight from someone else directed at me.
I have:
85 SC with Carb'd 305
85 mph cluster with the 3 light up (dummy) gauges and big fuel gauge
The donor car and cluster:
87 Z28 with Carb'd 305
115 MPH cluster with tach, and other assorted needle gauges.
My questions:
Is this gonna be a straight unscrew/unplug and plugin/screwin job?
If not why? what else do I need?
Am I going to have to find/buy a wire for the tach?
I've seen where others needed like a new oil pressure sensor and temp sensor? is this true or am I good?
Any and all responses will be GREATLY appreciated. I bought the 115 cluster this past week from a member, got it yesterday, and was hoping to put it in tomorrow.
Old 03-03-2012, 03:46 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Cluster swap help
At the very least, you'll need to change the sensors on the engine for water and oil from switches to gauge senders.
Old 03-03-2012, 03:57 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
http://www.oreillyauto.com/site/c/de...ressure+switch
here's the link to the oil pressure switch I'm looking at. is this the right thing?
Old 03-03-2012, 04:06 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
and this is what I found for the temp sender
http://www.oreillyauto.com/site/c/de...r%21s%21sender
Am I gonna need a new connector as well or will it be fine?
Old 03-03-2012, 04:34 PM
Al Hasse's Avatar
That's not the correct temp sender, you need one with a single wire like this one...
http://www.napaonline.com/Catalog/Ca...RecType%3aA%29
The oil pressure sender looks right, but by the title, it's a switch that just lights a light. When you get one, you need to specify that it's for a gauge. Most parts stores will have what you need...
Old 03-03-2012, 05:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/gauges
JamesC
Old 03-04-2012, 12:51 AM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
ok, so since I have the 2 wire connector, how do I go from the stock 2 wires to the new 1? put them together?
Also, where is the oil pressure sensor going to be located?
Thanks much!
Old 03-04-2012, 05:03 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Oil psi sender will either be at the back of the intake or down by the oil filter.
Old 03-04-2012, 11:00 AM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
how hard is it to get to the one at the back? I've read alot where they were down low w/ the filter but can't seem to find someone where it's on the back. is there one in each spot or is it one or the other?
Old 03-04-2012, 11:20 AM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
ok, here's what I've found for the Oil switch.
http://shop.advanceautoparts.com/web...PSESWAMS_____#
My problem is, NO ONE has the connector for it. All the parts stores are saying 3-5 days before they can get it in
Old 03-04-2012, 11:33 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
All you need is a simple wire connector that slides on it. Only difference with an actual connector will be that it has a rubber cover on it.
Old 03-04-2012, 01:03 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
I'm currently upside down in my car and I can not git the damn thing out! Any advice?!
Old 03-04-2012, 03:35 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
ok, we're good to go....kind of.... I got the cluster swapped out, I figured that what was holding me up was the 2 10mm nuts, then the fact that I don't have tilt steering wheel made it real hard to get in and out.
Now i have an issue, the speedometer starts @ (won't go below) 15mph, so if I'm going 50mph it'll show 65mph. any ideas? also, how soon do I need to replace the 2 senders/sensors? I was just gonna be careful and not drive too hard till I replace them.
Old 03-04-2012, 08:53 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Will a V6 115 speedometer work the same on a V8?
Old 03-04-2012, 09:11 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Did someone put any overlays on the gauges, as in they took the needles off?
Old 03-04-2012, 09:17 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
not to my knowledge...I know it didn't when I put it in. Why do you ask?
Old 03-05-2012, 11:15 AM
JamesC's Avatar
You may find some useful info about senders/sensors and wiring below:
https://www.thirdgen.org/forums/cool...re-sender.html
Is the cable itself seated correctly in the cluster and have you snapped the speedo connector securely in place?
JamesC
Old 03-05-2012, 12:09 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
As far as I know everythin is seated right
Old 03-05-2012, 03:32 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Ok speedo is working properly... I think. I just pulled the needle of and put it on right where the little line is below the 5 mph line and now its right for what I can tell. Now I have to replace some of the lights in the cluster.
As far as the temp sender, I thought that was the thing on the water neck, but apparently its on the drivers side of the block, can anyone tell me exactly where it is?
Jeremys87
07-14-2022 09:08 PM
Eric2ndGen
11-05-2015 01:51 PM
Bstrang6
09-08-2015 04:29 PM
355sbcTPI
08-19-2015 04:38 PM
ChevyZ71
08-13-2015 07:30 AM
Quick Reply: Cluster swap help
