headlights wont go up only down
Old 03-12-2012, 08:33 AM
reliantkcar's Avatar
86 trans am
headlights wont go up. i can only turn them on then screw them up.
when i shut them off they go down.
side note . the driver side one has the cover missing . previous owner said a tree branch hit the hood while he was driving so the top of the headlight is missing but it is still staight and goes up and down manually.
and if the headlights are off I cant raise them it fights me..
and ideas....
Old 03-12-2012, 01:07 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Re: headlights wont go up only down
I assume it is a 3 relay system. One on each fender and an isolation relay on the radio support wall near the battery. I would suspect you have a bad isolation relay. They are harder to find than the relays on the fenders. They are not interchangeable (can't use the fender relays fir an isolation relay).
Old 06-07-2012, 04:19 PM
baileysup's Avatar
Where can I find this part? I have the same problem with my 85 Firebird. What's a good place to find parts for these cars? Thanks
Old 06-11-2012, 06:35 AM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
If they go down, it's probably not an electrical problem.
The more likely issue is in the drive motor unit. Top Down Solutions
(check the vendor list in another forum) offers offers an economically
priced solution kit.
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
09-28-2015 11:55 AM
Quick Reply: headlights wont go up only down
