question about my distributor
Old 08-08-2012, 11:46 PM
napalm368's Avatar
Car: 1986 iroc z28
Transmission: 700-r4
HI. ill start off by saying that i never messed around with ANY distributor before.so im clueless here...im just trying to hook up my tach gauge.And instructions say to connect to a "direct tach output lead"..I see a small box on the drivers side of the dizzy. it says TACH BATT on it. then there is 2 plugs coming from that box. one is red and one is white...Am i supposed to splice into one of these wires? any help is greatly appreciated. thank you
Old 08-09-2012, 03:05 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: question about my distributor
Originally Posted by napalm368
instructions say to connect to a "direct tach output lead"..I see a small box on the drivers side of the dizzy. it says TACH BATT on it. .Am i supposed to splice into one of these wires? u
The white wire is the tacho signal you require but you should be able to find and splice into that wire under the dash
so you don't have to run a new wire all the way into the engine bay
Frozer!!!
01-19-2024 04:55 PM
Caspar
06-19-2016 11:19 PM
beastin91rs
10-09-2015 07:38 AM
86IROC112
08-17-2015 07:57 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: question about my distributor
