No Spark From Distributer???
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Alright if anyone has read my previous post, i now have power to my car, but now it turns over with no spark from the distributer (used spark tester). What should i check? I started the car a week ago and it was running fine, except it wouldn't charge the bat. when turning it off i lost all power again. I don't know what to do right now, i took apart my distributer, theres a little buildup that i will clean when i get home...
Any other ideas if that doesn't work???
Anyone know where the distributer power wire heads to?
Re: No Spark From Distributer???
The power wire to the coil is the the pink wire on the gray connector and is feed off the ignition switch.
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Engine: 305 5.0L
theres a red wire that connects to the connector where the tach goes, where does that go? i have a haynes repair manual, its labled "battery" does it go straight to the battery?
Car: 86 Z28
Engine: '06 LQ4
Transmission: GTO T56
Axle/Gears: 3.73 S60
I had the same problem with mine and it turned out to be the ICM in the distributor.
Engine: 305 5.0L
i loke the haynes book, its helped sooo much, but i actually hooked a tach to that port on the side, it works, so i know thats the tach port, but i have a red wire running from where that is and it goes into my harness. where does that wire go? thats the question i had. If needed ill get a pic of it.
Car: 1986 Monte Carlo SS Aerocoupe
Engine: L69 305 H.O.
Transmission: 200-4R
pull the distributor cap off and rotor button and put a new module in it. some parts stores at one time could test them. dont know if they still do or not.
Did have a coil take a duke 1 time on a monte carlo
Engine: 305 5.0L
just curious, can the icm burn and make smoke? cause before all this my cars power died and i saw smoke coming from the passenger side of the hood
Engine: 305 5.0L
also i turn the key in my car and get no response at all, could that be from the ignition control module too?
Car: 86 Z28
Engine: '06 LQ4
My ICM went out when I was driving so I'm not sure if it smokes or not. When I tried starting up my car the motor was turning over just not starting because there was no spark coming from the distributor.
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Hello,
Sorry to jump in here, what is the icm? Or is it just a short form for the module? Wait I just gooled it and "ignition control module".
Car: 1992 z28 purple orchid
Engine: 5.7
Axle/Gears: 373
My 92 is doing alot of similar stuff, anyone have an answer??? I've replaced the coil, icm, rotor and even wires now...plugs are reading 12v all across...help!!!
http://easyautodiagnostics.com/gm/4....ed-icm-tests-1
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
removed my comments because the car is entirely different to the original post
Hello guys , I’m new to the forum. I also have no spark on my 92 z28 . I have a new battery,new ignition coil, new distributor, new spark plug wires and new spark plugs. The car cranks but won’t start. I have 11.87 volts coming out of the red wire that feeds the ignition coil when I turn the key. I have no spark coming out of the ignition coil . Please help not sure what to check next. Thank you.
Do you have 12v to the icm ?
You might want to ohm the coil to icm wires they often fail overtime.
https://m.ebay.com/itm/TPI-TBI-HEI-S...ss!20707!US!-1
Gunner242
12-25-2015 04:49 PM
HoosierinWA
10-07-2015 10:15 AM
