Light Blue wire in C100 connector
Old 06-17-2013, 01:38 AM
djjon76's Avatar
Car: '84 Trans Am
Hi all.
Slowly working through the wiring in my '84. Have removed all the ECM stuff succesfully and this has cleared up my access to the C100 connector.
I have located a Light Blue wire that comes out of the C100 but is connected to nothing in the engine bay (it was just wrapped up)... BUT I just happened to check the continuity of the wire (took out the gauges) and it seems to be connected to just about everything in the dash even the positive connectors.
Fortunately, as it isn't connected to anything in the engine bay it hasn't casued any fuses etc to blow. It's almost as if it's just a ground, but that doesn't make sense if it's getting continuity from the positive side of the connectors in the dash.
Any ideas
Old 06-17-2013, 07:16 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: Light Blue wire in C100 connector
I havent seen an 84 diagram but the 85 shows a possible light blue wire used for turn signal lights and one for carb choke heater. Thats all that is light blue
Old 06-17-2013, 08:37 AM
djjon76's Avatar
Car: '84 Trans Am
I reckon its the choke heater wire. Turn signals work fine. IIRC mine is missing the choke relay in the convenience centre (will double check tomoz). But it still doesn't explain the fact that it seems to be wired a bit weird.
Old 06-17-2013, 08:50 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah that i am not sure. The austin thirdgen site has dash wiring for 82-84 cars and doesnt seem to show that circuit, atleast i didnt see it. You sure you traced it back correctly?
crt454
Interior Parts Wanted
06-23-2017 02:25 PM
TheJoeY88
12-31-2016 07:30 PM
eightsixseven
08-14-2015 03:09 PM
stalkier
08-13-2015 12:59 PM
Omega
08-10-2015 12:46 PM
Quick Reply: Light Blue wire in C100 connector
