92 camaro 305 tbi wont run unless alternator unplugged
Old 08-29-2013, 01:59 AM
Reaper Z28's Avatar
Car: 1992 Z28
Engine: 5.0 Tuned Port Injection
Axle/Gears: 2.73 posi
I've got my buddies camaro in my garage after the shop he had it at couldn't figure it out after having the car for over a month. They threw a bunch of parts at it. As it sits now it barely stays running and struggles to accelerate and bogs down and stalls. When you unplug the alternator it runs great (until the battery dies). So far I've tested all three wires using a test light and all of the wires/ visible links are good.also checked the fan fuse and its good. Has anyone had this problem/ know someone who has.
Old 08-29-2013, 02:11 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 92 camaro 305 tbi wont run unless alternator unplugged
Unplugging the alternator changes the injector pulse width making the engine run rich.
Besides testing ste electrical charging system/ connection. Ohm the injectors when the engine is warm IIRC 2.0-2.2 ohms, and you can even see the injector spray pattern with a timing light pointed at the injectors.
Old 08-29-2013, 02:31 AM
Reaper Z28's Avatar
Car: 1992 Z28
I can do that. But the injectors injector wires and ecm have been replaced.
Old 08-29-2013, 06:51 AM
cphgncowboy's Avatar
Car: 1991 Formula
bad alternator?
Old 08-30-2013, 03:31 PM
Reaper Z28's Avatar
Car: 1992 Z28
Tried 2 new alternators.
Old 09-07-2013, 01:19 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Bad or missing block ground?
Old 09-12-2013, 11:01 AM
James Tory's Avatar
I have this exact same issue. Have you found the problem ?
Old 09-15-2013, 07:25 PM
Reaper Z28's Avatar
Car: 1992 Z28
Still no luck I rewired the alternator and timed the motor. Now it runs but with a surging idle andwhen it's cold it bogs down if you give it more than a quarter throttle. Runs much better when the motor is warmed up but still hesitates. Still runs good with the alternator unplugged
Old 09-15-2013, 07:26 PM
Reaper Z28's Avatar
Car: 1992 Z28
Put a new block ground on it
Old 09-17-2013, 02:43 AM
Reaper Z28's Avatar
Car: 1992 Z28
I ohmed the injectors they measured 1.3 ohms. And key on engine off they measured 12.29V battery voltage 12.45V.
Old 09-17-2013, 04:13 AM
Engine: Lb9
Transmission: M20
The injectors ohm seems to be real low, you might want to contact member southbay08 to Confermation the injector ohms on tbi injector though.
Old 09-18-2013, 09:26 PM
Reaper Z28's Avatar
Car: 1992 Z28
The spec from another forum on here said from 1.16 to 1.36 ohms
Old 09-23-2013, 08:26 PM
cartech's Avatar
Car: 1988 IROC Z
Any news or updates on this issue?
Jae992
08-27-2015 09:07 AM
Tonyy_z
08-12-2015 07:20 AM
92purpz28
08-11-2015 02:30 PM
MENINBLK
08-05-2015 11:58 PM
Quick Reply: 92 camaro 305 tbi wont run unless alternator unplugged
