Gauge problems
Car: 83 Trans Am
Engine: 5.0
Gauge problems
When I start the car the temp gauge turns over all the way then goes back down. Is it the sender that is need of replacement or the gauge itself? I checked all the wires and they are fine and go to where they should.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Rage
It is normal when you start the engine for the gage to do that.
It is part of a testing circuit.
It proves the gage is functional.
Happy Racing !
After The Fourth Barrel Roll I Lost Control Of The Car
Happy Racing !
Car: 83 Trans Am
Engine: 5.0
Re: Gauge problems
I left a few parts out of that. I know that is normal function. The gauge does not function after that. I just drive for 50 minutes and the temp gauge didn't move. The car is cooling itself just fine but I would like the gauge to work properly.
I am assuming it is the sender on the cylinder wall that is faulty.
Transmission: 765R4
Gage Rage
Most likely the sender is defective or disconnected.
To find out if the connection from the sender to the gage is good, with the engine OFF, but the key in the RUN position, ground the sender wire, then look at the temp gage.
If the connection is good the gage will peg, therefore the next thing to look at would be the sender.
The temperature sender is located in the top left front of the engine most VINS.
Using an ohmmeter, with the engine cold and sender wire removed, probe the sender from the center pin to ground.
If the sender is good you will see approximately 1400 ohms on the meter.
Happy Racing !
Whether It’s A Street Car At A Traffic Light Or The Nitro Funny At The Strip, Yellow Means Floor It !
Happy Racing !
Ghettobird52
12-29-2023 08:23 AM
