FAST turn signal Flashing after rear gta wire harness swap
Car: 1989 Formula 350
Axle/Gears: 3.27 Posi
My 89 Formula, I switched out the rear wire harness with an older trans am style where the turn signal is in the brake a running lights in 1. I got everything to work on the switch over but now the turn signals look dim and flash really fast on both sides? Do I have to replace a different type of flasher now to fix that?
Fast355
12-02-2016 06:33 PM
